my project...e34 m5 turbo....
  • James Crivellone
    Head Janitor
    • 6304
    Originally posted by cramer
    haha, don't get him started about Mtec mirrors ;)
    I have some I can part with ;)
    • e30sd
      Fistee
      • Jan 2004
      • 5517
      FO REALS? if you're not keeping them let me know jamesy i wants. rather have real ones than the knockoffs.
      • James Crivellone
        Head Janitor
        • 6304
        I need to check the drivers side mount to make sure its not broken, but yep I have the real ones. This weekend I'll take a closer look.
        • eddie
          • Feb 2007
          • 78
          arggg, no m-tech mirrors!!!!!!!!!!!!!!!!!!!
          build date is 2/90, has the 4 buckets with center console.
          sls has been deleted already....
          pics of parts will be up tomorrow, camera is dead at work!!!
          • e30sd
            Fistee
            • Jan 2004
            • 5517
            very nice, mine's a 1/90, haven't stopped driving it since i bought it.
            • eddie
              • Feb 2007
              • 78
              yeah, i have had mine a lil over a year now, love the car, love the potential....
              • eddie
                • Feb 2007
                • 78
                few pics, nothin special...have the new water pump, oil pump and all gaskets on order...once i get the block back, i will order up the turbo...clutch will be here next week...
                coils..will use koni adjustables...
                fuel system and ignition system....will redo all fuel lines also...
                new block
                forged rods and crank..
                8:1 forged je pistons
                raceware headbolts and arp rod bolts
                will be building a manifold similar to this one..
                1000cc injectors..
                tial 44mm wastegate..
                my old 16v turbo..11.53@133mph 2500 pounds, 15psi...
                • Tavern Gnome
                  • 2137
                  God damn! I hope to see it around soon!
                  __________________
                  1987 Toyota Landcruiser V8
                  • george graves
                    • 19996
                    What do you have plans for in the way of intercooling? And is that a air-to-water intercooler on you VW?
                    Originally posted by Matt-B
                    • backtrail69
                      • Jul 2005
                      • 4471
                      What EMS? Hope to see this beast on the road soon. My turbo car is running 80x better than when I came down for that meet.
                      :: PNW Crew ::
                      '87 325 4dr, '74 2002
                      • Tree18is
                        • Mar 2004
                        • 2703
                        oh dear.
                        thats clean as hell, Lots of rare parts huh?
                        where did you source some of them?
                        • eddie
                          • Feb 2007
                          • 78
                          which would those be??
                          the vw ran an a/w intercooler, put ice in at the track, do a burnout, intake temps of ~65 degrees, run the run, get back to the pits, and still be under 100 degrees intake temp...
                          the m5 will be using a precision air/air core..rated to 950 horse...
                          management will be one of two systems..we are gonna try and use dfi's new system called the thruster, basically a scaled down version on the dfi v.7 system...it utilizes a crank trigger and distributor system...if it does not work, i will use sds..
                          • eddie
                            • Feb 2007
                            • 78
                            got the clutch in today, it is a uuc UltraSmooth Cerametallic..hopefully it holds up..the block is at the machine shop, should be done early next week...
                            • cramer
                              • 1812
                              Yay! No more throw out bearing noise ;)
                              Chris
                              90 Corrado/91 M3/01 M5
                              • CorvallisBMW
                                Long Schlong Longhammer
                                • 13039
                                subscribed
