The/My 88 M3 antfarm/rustbucket rebuild
  • cramer
    • 1812
    #106
    So is a tech day needed to get this car finished by M car day? ;)
    Chris
    90 Corrado/91 M3/01 M5
    • Mclassy
      • 270
      #107
      Looking like some solid progress.
      • smonkbmw
        Professor
        • Jun 2006
        • 4549
        #108
        PLEASE!!! that would be SUUUUPER SICK!! i have a box full of every valve train part listed on real oem thats brand new. the pump shims should be here next week.
        seriously cramer if you have the free time id be stoked if you could make it down. i dont have much but i could buy your fuel and lunch/dinner. let me know!
        • cramer
          • 1812
          #109
          I'm not an engine rebuild expert but I can definitely lend a hand and provide a reference motor ;) Between the Koala CD and factory manual we should be able to get everything where it should be!
          So looking at the calendar, we don't much time before the 24th. I may be able to come down on the Sat 23rd. That work for you and Curt? (I'll check my with my schedule maker tonight :D)
          Chris
          • smonkbmw
            Professor
            • Jun 2006
            • 4549
            #110
            23rd works for me. ill have to consult the shop owner and see what he thinks.
            • cramer
              • 1812
              #111
              Crap, the 23rd won't work for me (doesn't mean you can't have a tech day though ;)) I am still more then willing to help but it would have to be a weekend after M car day.
              Chris
              • smonkbmw
                Professor
                • Jun 2006
                • 4549
                #112
                shop owner says cool, so whenever works for you. thats ok that its not on the 23rd. gives me more time to get $$ together for oil, coolant etc.
                • smonkbmw
                  Professor
                  • Jun 2006
                  • 4549
                  #113
                  well.......
                  uofom3, e30groupie and i turned some wrenchs monday. took the intake plenum off. discovered more cracked rubber lines, a eroding wire harness sheath. due to the overwhelming analness (thats not a word, but screw it) of the other 2 people involved here, i think im gonna pull the motor and do a budget rebuild and clean up on the engine bay and motor. its not what i was planning on doing, but as many times as ive been told of the advantages of this concept, im gonna do it.
                  my MAIN concern is it makes it to the picnic next year, i want some sort of recognition for this car damn it, lol. so, ill be making more posts with pics as i pull the motor and commence cleaning and rebuilding. ill keep you all updated.
                  • FredK
                    • 14761
                    #114
                    Good luck with the rebuild! It's a lot easier to work on the timing system on a stand, and pulling an S14 is pretty easy because it's not too long of an engine.
                    • SiGmA_X
                      • Mar 2006
                      • 287
                      #115
                      Very cool Jeff, keep us in the loop, and if you and Curt ever need a spare set of hands, give me a ring. I'm looking forward to seeing the car up and running!
                      :wgaf:
                      PNW BMW Crew ///
                      '93 325iS
                      '99 528iT
                      • cramer
                        • 1812
                        #116
                        It'll take a little while longer and of course more $, but you'll know the motor is solid when you're done.
                        I'm just glad to see you sticking with the S14 after all this :)
                        Chris
                        • So Live
                          • 2512
                          #117
                          2.5 build?! :)
                          -Chris
                          • uofom3
                            • Jan 2004
                            • 5392
                            #118
                            Originally posted by So Live
                            2.5 build?! :)
                            negative.
                            Glad you're doing it bro. Should be a good time once we're done.
                            PNW Crew
                            90 m3
                            06 m5
                            • smonkbmw
                              Professor
                              • Jun 2006
                              • 4549
                              #119
                              2.5 build?! :)
                              sorry cant afford it.
                              hope to basically redo the whole bottom end as its reasonably cheap. have the head inspected and cleaned up and button it all back together with more new gaskets etc. thinking about shaving a bit off the flywheel, basically doing cheap "mods" while its all apart.
                              itll be pretty cool for me as ive never had a motor with technically zero miles. down the road im hoping for the fiberglass airbox and alpha n. and that will be it motor wise. im stoked and kinda tripping at the same time as ive never got this far into a motor before and im using a S14!! for my first attempt.
                              • smonkbmw
                                Professor
                                • Jun 2006
                                • 4549
                                #120
                                new pics. very close to pulling the motor out and doing a massive cleaning. current motor plans are:
                                -Metric Mechanic 2400 sport kit
                                this includes a new ($2000!!!) head, pistons, rings and head gasket.
                                -rod and main bearings
                                -block cleaned up and rebuilt
                                -cleaned cambox etc.
                                -balance/blueprint injectors
                                -Alpha N MAXX system
                                this plan will put me at 205hp (more with the alpha N) at the motor which im VERY ok with. i want more brakes and suspension then power. anyhoo on to the pics.
                                the nastyness discovered after UofOM3 pulled the intake plenum. torn wire sheath, FILTHY injectors and cracked hoses everywhere:
                                cruddy starter
                                cruddy throttles
                                E30Groupie choppin nasty, rusted exhaust bolts off the flange
                                ready for take off
                                /\ oh snap you can see one of the new "groupie projects" in the background!!
