The/My 88 M3 antfarm/rustbucket rebuild
  • e30edward
    • 777
    #121
    nice progress!
    keep us posted.
    • Farbin Kaiber
      Lil' Puppet
      • 29502
      #122
      Touring?
      • FredK
        • 14762
        #123
        Sweet. Once you get the engine out and the parts cleaned, things will go back together quickly! The engine looks disgusting now, but once everything's washed and painted, it'll look great!
        • guitardude
          • Apr 2008
          • 298
          #124
          what are you looking timewise to get this thing back on the road?
          • kencopperwheat
            King of Kegstands
            • 14396
            #125
            Progress. Nice man. I'd recommend just popping it on an engine stand and stripping the block down. I just did that to my M42, and it's nice piece of mind to get in there and replace every gasket/seal and clean every part individually.
            Originally posted by Gruelius
            • smonkbmw
              Professor
              • Jun 2006
              • 4549
              #126
              hopefully by the next picnic. it wont be "done" but at least drivable i hope. money is the issue really right now (isnt it always?)
              thats the plan!!
              • Van Westervelt
                • 9365
                #127
                As per the title, over 50% is done. The ants are all gone. :)
                • guitardude
                  • Apr 2008
                  • 298
                  #128
                  thats the plan!!
                  nice! i don't think these cars are ever done, but i can't wait to see how it turns out.
                  • cramer
                    • 1812
                    #129
                    Does metric mechanic to a core charge (send them your long block and you get a refreshed one) or are you getting the parts to rebuild it yourself?
                    Chris
                    90 Corrado/91 M3/01 M5
                    • smonkbmw
                      Professor
                      • Jun 2006
                      • 4549
                      #130
                      ill be sending them my head. thats all if i go with the kit. ill have to rebuild the block myself. if i went with the whole motor id send them the whole thing.
                      • smonkbmw
                        Professor
                        • Jun 2006
                        • 4549
                        #131
                        alright opinion time.
                        im stuck with a interesting debacle for what motor build to go with.
                        im kind of trying to stay under $4000 for the parts involved in the build. so answers like "dude, totally go with the full 2500 race motor" or "get the alpha n and carbon blah blah blah" really wont apply here.
                        A. i go with the Metric 2400 sport kit. kit cost is $3300est. gives me 205hp.
                        Upsides: A $2000 metric head that i could use over any block id want down the road, new pistons, rings, hg, only have to bore out to a 2.4 from 2.3, still use stock crank, and did i mention a $2000 head built by Jim Rowe?
                        Downsides: still have to by rod and main bearings, all that and only a 205hp output.
                        B. Turner 2.5 stroker kit and use a VAC head. kit cost would be close to A, right around $3300. im not sure what the exact output would be but it lists "increases torque by 50ftlb" and im sure the hp output would be near 225-240 with the VAC head.
                        Upsides: more torque!, bigger displacement, i dont have to get near as much extra parts as the metric kit, wiseco pistons (not stock items)
                        Downsides: have to get rod bearings, fasteners, alot more machine work for the block, no $2000 Jim Rowe head :(
                        what cha think?
                        • e30this
                          • 3580
                          #132
                          B
                          • Eric Giles
                            • 1068
                            #133
                            Since you are on a budget, I would choose option A-heck I would probably go with that option even if I wasn't on a budget as it sounds like a good overall deal to me.
                            Eric Giles
                            '20 M2 CS
                            '04 M3
                            '11 X5 35D
                            '87 325is
                            '91 325i Sport
                            There are few things more expensive than a cheap BMW...
                            • Van Westervelt
                              • 9365
                              #134
                              Daily = A as there is plenty more work to get done to make it driveable.
                              • uofom3
                                • Jan 2004
                                • 5392
                                #135
                                Option A.
                                You don't want to know what the second option would cost you in the end. Try more like 8-10k by the time you're done with all the extra things you're going to need to get to make that work... for starters:
                                - evo AFM
                                - evo injectors
                                - evo chip
                                - 2.5 liter head gasket
                                - etc.
                                that's a couple of grand right there.
                                go with option A - i don't understand why you're still trying to change your solution. pick a plan an execute it.
                                PNW Crew
                                90 m3
                                06 m5
