!!!!!Caution M20 porn inside!!!!!
  • Dominic49
    • Feb 2007
    • 1373
    #136
    Originally posted by AriasATX
    Well that's great then, The 2 set's of busa TB's I have had sitting around forever are somewhere around 42mm I/D. Perfect for my plan's.
    what are those plans? ridiculously oversized itbs?
    • Miasma
      • Apr 2007
      • 2009
      #137
      Much larger motor there slick. Not a M20 i'm working with.
      Choice of bore size is a balanced compromise resulting from the following;
      1) A larger bore leads to lower flow resistance, but obeying the laws of diminishing returns.
      2) A smaller bore leads to better throttle control and response (never underestimate) and improved fuel mixing.
      3) The system should be considered in total - from (at least) trumpet flange to cylinder and proportioned accordingly
      Basic references for BHP per cylinder, assuming ca 120mm from butterfly to valve head and a max of 9,000 rpm are;
      Up to 30 - 30mm, up to 33 - 32mm, up to 39 - 35mm, up to 46 - 38mm, up to 51 - 40mm, up to 56 - 42mm
      Up to 65 - 45mm, up to 74 - 48mm, up to 80 - 50mm, up to 87 - 52mm, up to 93 - 54mm.
      These power figures may be increased by up to 10% in a purpose - designed and well proportioned system.
      As butterfly to valve distance increases, butterfly size will need to increase in proportion to system taper and vice versa.
      Lower revving engines and those with injectors placed before the butterfly will generally accept a larger body.
      Taken from The Jenvey F.A.Q.
      I am building a M30. Not only that but it's getting stroked and built for a turbo. Ill be just fine.
      Ill only be losing out on Throttle response if anything, And prolly not even that due to the FI. Even so it will rev much more freely than stock.
      • rs4pro3
        • 5808
        #138
        Started another little project today, just waiting on some Bosch coil drivers to come in the mail, to finish wiring it all up.
        85 325e 2.7 ITB'd stroker
        • uofom3
          • Jan 2004
          • 5392
          #139
          yup... that's a stout m20.
          PNW Crew
          90 m3
          06 m5
          • Miasma
            • Apr 2007
            • 2009
            #140
            Man that thing is sexy looking, Any plans on cleaning/painting it (the engine bay) after you get all the small thing's ironed out?
            • george graves
              • 19996
              #141
              good work!
              Originally posted by Matt-B
              • atomic
                • Jun 2007
                • 5691
                #142
                I doubt it.. That car is built to go not for show !! ;)
                • Jean
                  • 18228
                  #143
                  I wish I had your skills!
                  • rs4pro3
                    • 5808
                    #144
                    I'm probably going to throw a painted I valve cover back on it at some point but that's probably it. I'd love to get everything sparkling clean and painted but just don't have the patience or time to do it.
                    • Miasma
                      • Apr 2007
                      • 2009
                      #145
                      That's cool too man! Thing is gonna shit and git! Doesnt need to be clean. :D
                      • N2MYE30
                        • Oct 2007
                        • 5536
                        #146
                        WOW!!! Great job!!!
                        COTM
                        • chbimmer
                          • Aug 2004
                          • 165
                          #147
                          Update.....More Videos? Anything?
                          1989 Turbo 325is
                          87 ETA Dinan Stg 2
                          • SamE30e
                            • Sep 2007
                            • 4319
                            #148
                            Thats gorgeous!
                            1985 325e 2.8 Turbo VEMS
                            • Ray McCooney
                              • Jun 2006
                              • 1088
                              #149
                              Ely, you are the single most impressive individual on this site in terms of ingenuity. I will now admirably refer to you as the E30 MacGyver. Please do continue. That is all.
                              • chbimmer
                                • Aug 2004
                                • 165
                                #150
                                MacGyver.......what is that thing held together with bubble gum and fishing string?
                                1989 Turbo 325is
                                87 ETA Dinan Stg 2
