!!!!!Caution M20 porn inside!!!!!
  • Dominic49
    • Feb 2007
    • 1373
    #121
    Originally posted by rs4pro3
    280mm disks all around, rx-7 4-piston calipers up front, 25mm MC(I'm going to go back to stock to get some more line pressure with the manual setup), e30 m3 rear calipers with solid guide bushings, Wildwood adjustable bias valve, Master cylinder and pedal rod pickup moved 1" up to get more leverage.
    I haven't put the blower back on yet, and am debating if I will or not, TN-325i rode around with me yesterday helping me do some tuning, and said it felt almost like it had the blower on it.
    any more pics of the MC setup... namely the connections to the pedalbox. did you reinforce the pedal at all? seams as though there would be alot more force being put on the pedal
    • rs4pro3
      • 5808
      #122
      I've got a short video uploading right now of the ITB's in action, I'll post it as soon as it's done loading
      Hey Dominic49 I moved the pick up point 1" and had a 1/4 diameter steel rod welded in to help reinforce it. Then I just used some high strength m12 threaded rod and threaded into the stock clevis, and ground the end that goes into the master cylinder smooth. I'll see if I can snap a pick under the dash some day for you.
      85 325e 2.7 ITB'd stroker
      • rs4pro3
        • 5808
        #123
        Ok here is the video, I really need to change out the heavy ass eta flywheel that is still on the engine, as the revs stay up there forever before dropping back down.
        • CorvallisBMW
          Long Schlong Longhammer
          • 13039
          #124
          http://video.google.com/videoplay?do...72648717105027
          Ya, if you've got those sweet-ass ITB's you def need a lightweight flywheel. I find the 15lb single mass from a euro e30 323i works very well :) Of course there are numerous aftermarket options too
          EDIT: just watched the movie with sound, and you're not kidding! that thing holds on to revs like it was in gear coasting! get a ltw flywheel asap
          • Dominic49
            • Feb 2007
            • 1373
            #125
            thanks again. i'm going to go for a simalar setup on my m62 swap. :D how do the brakes feel? need better leverage?
            • moatilliatta
              • 6152
              #126
              LOL, valves so loud. Need some action video of it doing some work. You got a parts list?
              @Zakspeed_US
              • rs4pro3
                • 5808
                #127
                I'm still kicking myself in the butt for selling the 323i flywheel I had a few years ago, but that is when I had the m30 so no use for it then.
                • So Live
                  • 2512
                  #128
                  Sounds pretty snotty dude! Get that blower on there!
                  -Chris
                  • Mfever
                    • May 2007
                    • 1058
                    #129
                    sounds fucking ridiculous, I love it.
                      • 37833
                      #130
                      Ely, awesome work.
                      Grover Beach, California
                      BimmerHeads.com
                      • Miasma
                        • Apr 2007
                        • 2009
                        #131
                        Sound's great, What is the I/D on those TB's?
                        • rs4pro3
                          • 5808
                          #132
                          34mm
                          • Miasma
                            • Apr 2007
                            • 2009
                            #133
                            Opp's just read it on page 2. You so fast!
                            • Miasma
                              • Apr 2007
                              • 2009
                              #134
                              Well that's great then, The 2 set's of busa TB's I have had sitting around forever are somewhere around 42mm I/D. Perfect for my plan's.
                              • Jean
                                • 18228
                                #135
                                I love it!!! Keep at it :)
