An M30B35 Swap Story
  • Miasma
    • Apr 2007
    • 2009
    Very cool stuff man! And I dig the Valve Cover for sure.
    • ejnight
      • Apr 2007
      • 3488
      http://raceskids.com/
      • VacMan
        • Apr 2007
        • 2405
        I saw your car there last weekend when I stopped by to pick up a trans. Looked good! Did you guys figure out the hood fitment issue yet?
        • speedhop
          • 1509
          Yeah...the hood fitment. I can't run the afm cover or i'm going to have to take off the hood insulation. It shouldn't be that big of a problem, considering the other hiccups we've had.
          www.ryanwhopkins.com
          • george graves
            • 19998
            congrats dude!
            Originally posted by Matt-B
            • speedhop
              • 1509
              It drives!!!!!!
              • e30s52
                • Oct 2007
                • 5235
                get a video up
                www.gutenparts.com
                • speedhop
                  • 1509
                  First...who wants to give me the secret to the m30 bleeding?
                  I also need to do a valve adjustment, change the oil, and get the exhaust finished (they couldn't fit the welder in between the firewall and the exhaust).
                  • BDK
                    • Jul 2008
                    • 684
                    there's a bleeder screw near the thermostat,
                    get the nose up in the air as far as you can and if it still won't bleed all the air out...
                    back the car up a steep hill...
                    this has always worked for me....
                    I don't understand the reverse up a hill part but it works...
                    • GaryE30
                      • 4791
                      should be able to bleed sitting at a level surface but if you need to you can do it on an incline, with the nose facing upwards.
                      Estoril E36 M3/4/5 | Toledo E53 X5 3.0 | LeMans E90 335D M-Sport
                      • funcrew
                        • Jun 2007
                        • 1223
                        Not sure if this will work on an M30, but on an M20, it works to (cold engine!) open the bleed screw, take off the coolant tank cap, and blow into the coolant tank. That's right - stick your kisser on the tank neck like playing the tuba. This is pretty gratifying because you can hear a lot of gurgling as all the air pockets purge out. When air stops coming out the bleed screw & coolant starts seeping out, close the bleed screw and top up the tank. Let me know if it works on the M30.
                        BTW Thanks for your PM.
                        "If the sky were to fall tomorrow, the tall would die first."
                        -Dr. Paul Forrester
                        Do I LOOK like I need a psychological evaluation???
                        • speedhop
                          • 1509
                          Thanks for the replies...what happened was the AC fan wasn't on and I wasn't getting any "windage" ha. So at idle it would heat up. Fixed now.
                          It was bled fine and runs at about the 1/4 mark. Thanks for all of the input.
                          funcrew: You're welcome!
                          • joelslong
                            • Nov 2011
                            • 1
                            soooooo??
                            whatever happened to this?
                            i'm reviving my '91 m42, and i'm considering this swap..
                            very curious!
                            new to the forum btw.
                            and sorry to bring a three year old thread back to life.
