There is no evidence of detonation on the spark plugs.
Ultimate budget build.
There will be if you keep driving it. I remember hearing these same sounds in some performance cars that have octane requirements.Comment
MegaSquirt, Your car is beginning to revolt against the air you are shoving down the plenum, like a supermodel being force fed two big macs a day. Eventually she will pop, or fall off the runway.Comment
I don't know if it works on M42s, but on the M20 if you disconnect the TPS it will retard the timing. it might make your idle a little wierd though. Of course if it doesn't work you can plug it back in.Comment
no, it runs in the base map, the TPS is basically a idle/cruise/WOT switch. If the computer doesn't see a signal it defaults to the cruise map.Comment
•• Powersteering Deletes • M20 Motor & Trans Mounts • 24V swap mounts • UHMW Offset CABs ••
•• Rear Subframe Bushings • RTABs • Facebook ••
Handful in what ways Danny? Are you talking in terms of power delivery or handling?Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
your suspension and tires good? that's probably the single most important component for events like autocross....
So did you fix your detonation issues? running good now?Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
