My E30 325i. Slowly getting on it's wheels
  • Larsinnj
    • Jan 2009
    • 134
    #91
    An original intakemanifoil have died! :( But is was for a good cause. :D
    Need to figure out the angle the new intake will have, and cut it a bit more. And i obviously have to make that cut a far in so that the holes are in a perfect line. I hope I can use the factory mounts for the fuel injectors. As far as I can see now I think it will work.
    Stay tuned. :)
    • Kershaw
      • 11822
      #92
      nice man. good luck.
      AWD > RWD
      • Larsinnj
        • Jan 2009
        • 134
        #93
        Thanks! :)
        I'm away for work right now but I'm going home on friday. I hope I can do some work on it this weekend.
        I have to figure out how big the angle must be. When I lay the S50 intake against the head it points almost straight down. So I have to angle the flange the intake will be bolted against upwards.
        It turned out to be a bit more work than I had expected but far from impossible! :D
        • Larsinnj
          • Jan 2009
          • 134
          #94
          The intake is on standby for now. I don't have equipment to do more than I already have, so I have to wait for a buddy to help me.
          I took out the camshaft today. I'm replacing it with a performance camshaft because of a massive loss of power from 4000 rpm and up. I have read several places that a sharper cam wil make that better. It's not a super sharp cam I have got. It's 280 degrees, so I don't even think I will get that rough idle.
          Rockerarms out:
          Out, and in correct order:
          Camshaft is out aswell:
          The reason I had a oilleak. Very bad seal at the front of the camshaft.
          • Larsinnj
            • Jan 2009
            • 134
            #95
            280 degree camshaft bakck in:
            Rockers on the exhausside fitted:
            Turned the car around and started on the bakside.
            My plan was to replace every brakepipe, but when I got a closer look the ones that is allready there is in good condition so I didn't bother.
            But the differential had to go!
            Old vs new:
            Didn't go all after my plan. When I was almost finished pressing in the new bushing, the rear lid cracked. A littlet setback, but I went to a local shop, and they welded it together again. :)
            Now the new diff is in place! Looking forward to spin on both wheel this summer! :D
            I also changed the wires for the handbrake. They were far from good condition.
            • Larsinnj
              • Jan 2009
              • 134
              #96
              Bought a new set of rims today! :D
              You'll have to wait to hear what kind, but I can reveal: It wil be win! :D
              • Larsinnj
                • Jan 2009
                • 134
                #97
                Got some pics of the new rims today! :) 8,5 and 10x17 OZ Hartge! :D
                The centercaps are missing but I know where to get new ones, so that's not a problem.
                Just have to start looking for M3 hubs and brakes now! :P
                • Larsinnj
                  • Jan 2009
                  • 134
                  #98
                  • Larsinnj
                    • Jan 2009
                    • 134
                    #99
                    Got something done this week too.
                    First of all, I took out the sunroof. It was full of rust, so I removed all the rust and painted it with rustpaint. Nothing showing on the outside.
                    Then I opened the drainpipes from the sunroof. They were full of old dirt.
                    After that I replaced the floormat. The old one was from a E36, so it didn't fit very well. A buddy scrapped a E30 touring a while ago, so I got the mat from that.
                    M-seat was also fitted. :)
                    Old vs new
                    "New" floormat fitted
                    Centerconsole in place
                    M-interior in place
                    • 323iNathan
                      • 232
                      #100
                      Looks Great. Seriously Jealous about the wheels!! They are sweeeet!
                      • KristianF
                        • 19
                        #101
                        This is gonna be great.
                        • Larsinnj
                          • Jan 2009
                          • 134
                          #102
                          I think so too, Kristian. :)
                          Cool that you like the wheels! :D I will buy new centercaps, but I won't paint them in that color until I have the wheels on the car. I wan't to see how the colors match first.
                          But I sereously believe that it will be perfect in that color.
                          Just needs to be a bit lower. Considering coilovers when I rebuild to 5-lug. :)
                          • Larsinnj
                            • Jan 2009
                            • 134
                            #103
                            My MHW tail-lights finally arrived today. Can't say tha difference is that big from the old ones, but at least theese are original. And I have another set of tails. I will paint them red and see what I like best. :)
                            Dirty car! :thmsdn5:
                            • Larsinnj
                              • Jan 2009
                              • 134
                              #104
                              Did some photoshoping today. Found out that yellow and gold doesn't really fit together. It's wasn't a very good shop, but you see how it will be.
                              I also lowered it, fixed some scratches in the paint and made a silver M5-stripe at the bottom of the front and side skirts.
                              What's your opinion on the wheels? Keep them as it is, or paint them silver?
                              • Larsinnj
                                • Jan 2009
                                • 134
                                #105
                                Centercaps for the wheels have been bought, and the center of the wheel itself have been painted. A friend of mine have the lips and he will sand and polish them! :D
                                Can't wait to get these on the car. :p
