Small update today. (I told you they would come more often ;) )
I had to climb in the attic to get a friend at work my old E30 steering rack as his is leaking. This requires moving the E21 which is no small feat as the battery is dead. Conventional wisdom would dictate, "hey dummy, go get a new battery so you can drive the damn thing." Alas, I did not heed the advice coming from that annoying cricket on my shoulder and preferred to listen to the little horned guy that says laziness should prevail. I backed the E21 by pushing it, climbed into the attic and grabbed the steering rack. While I was there I grabbed the rear door cards so I could play with them. Pushing the E21 sucks so I jumped it and put it back in place. With that done, the wife at the grocery store and a beer in hand, I decided to play with the rear door cards.
Stripping the leather was boring so I took no pictures. The aftermath however left me pondering.
I wanted to keep a similar theme as the front door cards, using similar proportions, etc. I hung the panel in the back and made some marks after looking at the front panel with the door closed. With the marks established, I made a sketch of the material to be removed.
Since there will be no back seat, the arm rest was useless. The extra width at the front was necessary to have things line up appropriately. This is a two piece panel and will require some thought when assembling it. But for now I tore at it with the dremel and made a big hole.
It's a very rough cut but I did that so I had extra material that would allow me to straighten and smooth it all. Laying over the carbon fiber looks pretty good too.
The carbon will need to be trimmed along the top to allow it to fit properly. But for now it should give me an idea what it will look like in the car.
It should come down lower when I trim the carbon and line up better with the side cards.
Now to get the other side done and measure for the alcantera order!
