If you had unlimited funds to build a E30 track car...
  • Turf1600
    • 9815
    I am serious. It would get attention on the internet.
    • FredK
      • 14763
      Same. That is the most Gran Turismo/F&F fanboy inspired build for a "racecar" I have ever seen.
      Hey dude. If you got into my Stage 3 Weight Reduction E30 you'd be singing a different tune. It's got hollow M42 cams, undercoat delete, all aircraft fasteners, and a 2150 lb curb weight.
      • Miasma
        • Apr 2007
        • 2009
        Strip down a shell, Riddle it with bullet's, Install cage, Reassemble, "Race".
        • Miasma
          • Apr 2007
          • 2009
          Originally posted by FredK
          Hey dude. If you got into my Stage 3 Weight Reduction E30 you'd be singing a different tune. It's got hollow M42 cams.
          And lightweight advanced aircraft wiring.
          • FredK
            • 14763
            I think with some Ti-nitrided wheel fasteners to replace the stock chromies, you could look good and reduce weight on the perimeter of the those XXR002s.
            • hank_bukowski
              • Mar 2008
              • 192
              i start wqith 1990 325is
              remouve m20 an in stall m42
              install high compressin
              cut all belt
              2.92 open dif
              put alternater in trunk
              in stall electric water pum
              all alimunim drive shaft
              4 inch solid gold (4 the heat) exhost
              mastercraft break pads
              solid gold break roters (4 the heat)
              trade efi 4 pierberg sidedraft carburraters
              curtom chip
              cut m3 springs
              85 318is \\\M
              up date mods:
              roundel subscription
              mega time attack bottlecaps
              extra cut springs
              wiper blade delete
              racing slick tires
              nite-shadez headlights tail lightsmand windows
              xtra mods:
              cut belt
              sanded spark plug
              air filler delete
              even more cut springs
              broken ac delete
              more:
              more cut belt
              bettered:
              crome fender trim
              crome spray nozzle
              cut off exhost
              body color grillz
              ran bumbers n2 wall
              blue under body lites
              neon wheel wells an calipurs
              new:
              eyebrow
              black gills
              more head lites
              • FredK
                • 14763
                ^ sounds good. You might want some custom halfshafts to handle all that power.
                • hank_bukowski
                  • Mar 2008
                  • 192
                  thats y i start witrh 325is
                  85 318is \\\M
                  up date mods:
                  extra cut springs
                  wiper blade delete
                  racing slick tires
                  xtra mods:
                  cut belt
                  sanded spark plug
                  air filler delete
                  broken ac delete
                  more:
                  more cut belt
                  bettered:
                  crome fender trim
                  crome spray nozzle
                  cut off exhost
                  body color grillz
                  ran bumbers n2 wall
                  new:
                  eyebrow
                  black gills
                  more head lites
                  • Massive Lee
                    • Sep 2006
                    • 6785
                    OP - Go back to sleep. ;)
                    massivebrakes.com
                    • BenM
                      • 2184
                      ^^^ Also needs KYB performance gas shocks to handle those cut m3 springs.
                      Originally posted by BillBrasky
                      E36's are the Stephen Baldwin of the 3 series family. They barely hold everything together and they only sold a lot because of the popularity of their older sibling.
                      1991 318i Alpine II - S50/5-lug swapped - track car
                      1989 325i Cirrusblau - Daily
                      1970 2500 - Malaga over Grey Cloth
                      2012 F350 6.7PSD
                      • FredK
                        • 14763
                        I think some Rancho Ford Ranger shocks would have a better damping curve for cut M3 springs. Are we talking E30 or E36 M3 springs.
                        • BenM
                          • 2184
                          E36 M3 springs. You are correct as the ranger shocks are undoubtedly superior for the high rates that cut M3 springs have.
                          2012 F350 6.7PSD
                          • Pinepig
                            • Sep 2007
                            • 1811
                            Start with a 2002.....
                            • triggrhaapi
                              • Feb 2007
                              • 350
                              Originally posted by ALYKZANDYR
                              Im bored, so i ask this question, If you had a unlimited funds to build a E30 race car, what parts would you use, what would the specs be? be creative!
                              For me:
                              start with 87 M3.
                              Custom build V12 producing 1200-1500HP
                              6-speed racing trans
                              Install braking system from an F1 car
                              preform extensive weight reduction, everything not needed must go.
                              Full carbon fiber body panels
                              Full titanium structural body members,
                              install best racing suspension setup that money can buy.
                              Have BBS make me titanium versions of a wheel set of my choosing
                              titanium roll cage.
                              carbon fiber dash w/ Motec ADL
                              Metallic silver paint, hood left unpainted, but with glaze to protect carbon fiber from sun damage.
                              I imagine the most amount of useful power one could produce would be in the 550-600bhp range.
                              I would widen the flares, install a standard bbk front and rear with bias controls in the cockpit.
                              Motor would probably be a S50US with a twin scroll GT35R and custom tuning set up to produce max power with traction in each gear.
                              Suspension would probably be something custom, I really don't know enough to know what would be best so I'd defer to some guru.
                              Probably wouldn't do all that to an M3 either, they're too rare to be ruined by the race track.
                              1987 BMW 325is | Frankenmotor S50 | Supersprint Replica Headers | K&N Intake | Gutted Stock Midpipe | Zimmermann Rotors | Stainless Brake Lines | Porterfield Racing Pads
                              • BeirBrennerE30
                                • 2740
                                Build time machine... go back 4months. Buy Sauber BMW from BMW. Tell everyone there that they are no longer racing F1. Their new goal is to build you the most insane car ever with no restrictions on anything. One catch though... has to look like an e30 when complete.
                                e30sport.net
                                '06 M3 Competition - 6-speed
                                '97 Range Rover Vitesse
