1981 VW caddy high idle.
  • Danny
    • 14216
    It idles at right around 2000rpms, I've replace the fuel filter, the lambda sensor and checked all the vacuum lines. I am seriously stumped by this. It has the CIS fuel injection.
    I thought it might be the idle adjustment screw in the AFM type thing it has but the screw is stripped and I cannot adjust it. Also, I don't think its injectors because I sprayed fluid all around them and rpms didn't change at all.
    Again, I'm stumped, any help?
  • e30frosh
    • Dec 2004
    • 2170
    Make that screw work for you. My 81 two door did the same.
    Every day I wake up we drink a lot of coffee and watch the CNN
    Every day I wake up to a bowl of clover honey and let the locusts fly in.
    Lobsterbacks attack the town again
    Wrap all my things in aluminum
    Beams of darkness streak across the sky
    Pink rays from the ancient satellite
    Every time I look out my window same three dogs looking back at me.
    Every time I open my windows cranes fly in to terrorize me.
    • Danny
      • 14216
      wut
      • kylekrueger
        • Oct 2009
        • 250
        if the screw is stripped and you can't adjust it then you may have to get a new fuel distributor. I would try and make the screw work.
        • Massive Lee
          • Sep 2006
          • 6785
          Damn K-Jetronic. CIS is very sensitive to adjustments. You may want to look for a proper crew, and get a looooooooooong allen key.
          massivebrakes.com
          • .cj.
            • Oct 2006
            • 79
            What kind of condition is the intake boot and throttle body boot in?
            Is the meter moving freely?
            BTW, the allen is a 3mm and as Lee stated, it needs to be long.
            The rides-
            '68 Camaro- 511hp 388cid, Tremec 5 speed, Baer Brakes, Hotchkis suspension, 18" Budniks, Recaro seats
            '73 2002- Metric Mech. 2200 efi, 5 speed, 3.90 lsd, G/C suspension, 17" BBS LM's, Recaro interior
            http://www.cardomain.com/ride/792851
            http://www.bmwmregistry.com/detail.php?id=2812
            http://www.cardomain.com/ride/792793
            • der affe
              Technical
              • Dec 2005
              • 8452
              i forgot to tell you about the air flow meter plate. take the boot off and look at the level of it. it should sit level with the narrow part of the taper in the cone. if it is high or low, bend the spring steel clip to make it sit level when the car is off. over time the clip gets bent from it slamming down on it.
              also you will probably need to mess with the adjustment screw. you need to look for a BAP/GEON if you can find one in your town (i know that they were in san deigo still years ago) they carry the EMPI brand parts and you can get the t handle allen for around $15 from them. otherwise look on TECHTONICS TUNING's Web site and order one from them ( i think they were the cheapest shop to order them from)
              also remember you need to make your adjustment, then rev it and let the air flow plate settle. DO NOT rev it with the allen in the screw as it will change the adjustment.
              they also make a CIS specific injecter cleaner. i think it is called Jetronic, it is made by LURBOMOLY. Napa carries it so you should have no problem finding it. i don't know what is so specific about it, but it works really well at breaking up deposits in the fuel distrubtion blocks. they have VERY small passages that pulg easily if the car sat for any length of time.
              i don't remember if those cars had an idle air motor, but on the early A-2 cars, the boot that they popped into was prone to tearing and creating leaks.
              if you can't get the screw to work for you, and have trouble finding a replacement air flow meter (minus the fuel distubutor) i can see if i can come up with 1 from my friends shop at a decent price.
              • Danny
                • 14216
                Yeah look for one for me please, Greg. I've also been reading about the AAR.
                • Massive Lee
                  • Sep 2006
                  • 6785
                  Minimum length. I had a Hazet and it was three times as long.
                  massivebrakes.com
                  • Danny
                    • 14216
                    Also I tried the idle screw and it does nothing, but when I pushed down on it the idle went down until I let up on the screw, then it picked back up.
                    • MonkeyMadness
                      • 3251
                      Did you check the throttle cable?
                      • Danny
                        • 14216
                        Yes throttle cable is fine. All the intake boots are new.
                        • MonkeyMadness
                          • 3251
                          Spray carb cleaner around the base of the intake manifold.. you may have a leak?
                          • Danny
                            • 14216
                            No easily visible vacuum leaks, as stated in the OP.
                            • Ryann
                              • 3350
                              Quit messing with the screw. That's the idle mixture screw. The only way to properly tweak idle speed on a CIS VW is to adjust the throttle stop at the throttle body. You probably either have an auxiliary air valve that is stuck open (it's the cone shaped thing at the rear of the intake manifold that allows air to bypass the throttle plates) or burnt/shrunken injector cups/seals.
                              If, however, you're dead set on fucking up your idle mixture give me your address and I'll mail you the official Bosch CIS idle mixture adjusting tool.
