who knows volvo?
  • Dj Buttchug
    • Jun 2010
    • 7688
    who knows volvo?
    I cannot figure out what trans I need for a five speed swap. What are my options here? I want an m47 5 speed to bolt up to my b230ft. Car is 1991 940se
    Ive researched and came up with this:
    1: t-5 swap
    2: m46 4 speed with electric over drive
    3: m47 II 5 speed
    turbo bricks is usless... where are the volvo masters? I know there are some here.
    What the FUU do i need for a m47 swap. better yet, Where do i even buy one? can i even buy one?
    enlighten me please. I want to swap and slam my car.
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
  • Jaxx_
    • Dec 2009
    • 1880
    volvo... lol
    tb is usually the best place to find answers for that, to be honest. if it was newer, VS or SS. As I understand, most of the guys stick with the M46. I could be wrong though, I'm a FWD whore. ;) 855 and s70 owner.
    • MonkeyMadness
      • 3251
      t-5 really?
      If you go t-5 make sure it's the world class t-5 much stornger and better grearing
      than the reg t-5
      Or you could spend alittle more and go for the t-56 6psd
      good luck :-D
      • tjts1
        • May 2007
        • 1851
        If you're planning any clutch dumps, pay up for the T-5. If you don't abuse it a post 88+ M47 should be fine. The M46 is stronger but also much heavier, older and the OD is possibly worn. I think your 91 should have LH2.4 or higher so make sure you get the correct late style flywheel with the timing windows. Actually check to see if you have a crank sensor. I'm not 100% on that. You're only source for parts is the JY. The vast majority of manuals came in 240s so you'll need to find a 740 for the correct shifter linkage, pedals and front half of the driveshaf. Some people have welded up their own linkage to make it work in the 740/940.
        I did an M47 swap on our 89 240 about 5 years ago. I think I spent about $400 on it including a new clutch. GF crashed it 3 months later. Moved on from RWD volvos. And yes TB is useless but its pretty good for search.
        good luck
        • Dj Buttchug
          • Jun 2010
          • 7688
          ^ nice man. thank you. end thread
          Ig:ryno_pzk
          • dirty30
            • 3097
            PM towerymt on turbobricks
