Chevy power steering help needed! Get in here!
  • Vtec?lol
    • Dec 2009
    • 3278
    Originally posted by mrsleeve
    ummm there is a reason things are called small block.............. the out side dimensions of the engine are about the same size. Really there is not that much difference in physical size from a ford 302 and gm 350. the numbers you are referencing are Displacements (the volume the pistons displace) not overall size, seems like you should know this. If its a 3/4 burb with a gen VI 454 big block then you have a little less room as they are a little bigger, but I have a had 93 and 98 trucks with that engine in it and you still have lots of room under there to sit in the engine bay and work.
    The engine code your looking for is L31 aka the vortec 350
    There we go. Thanks.
    But c'mon man, are you really insulting my hot rod knowledge?
    As far as sitting in there and working, I just don't see how that's possible. Maybe if you remove the radiator and A/C comp. that has lines covering everything and once you f'k up and move the compressor the wrong way "BOOM" there goes all your freon. ask me how I know.
    I'm not one to down chevy guys, the L-series engines have been the shit and the fact that they are still using pushrod technology says a lot about them. Granted you guys have bigger engines in smaller sizes. I'm just and will always be a ford fan. Smaller volume, higher compression, same amount of output.
