Valve spring compressors.
  • Pantless Spency
    It's McRib time!!!
    • Feb 2011
    • 7283
    currently working with this inside my eta head... such a PITA
    autozone no longer rents out C-clamp style ones and i have to use this piece of trash.
    just wondering if anyone in here owns or has used anything differently and how much did it cost them?
  • Pantless Spency
    It's McRib time!!!
    • Feb 2011
    • 7283
    ffffuuu im about to punch a wall this thing pisses me off so bad...
    ive only gotten 3 out of 12 valves out since like 8:30 or 9:00 earlier.....
      • 37832
      Those pretty much don't work in an M20. Best is to use a drill press with a modified socket to compress the spring.
      Classic BMW Specialists
      Grover Beach, CA
      www.BimmerHeads.com
      • whodwho
        • Jun 2008
        • 1547
        Getting them out is easy putting them back in is the harder part.
        For getting them out use a spark plug socket and a hammer with a rag in the combustion chamber put the socket on the spring retainer and give it a good smack and wear protective glasses.
        My M20 Frankenbuild(s)
        4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
        • ForcedFirebird
          • Feb 2007
          • 8300
          A magnet helps with this too.
          I bought the c-clamp style, works great on the m20, but had to make an adapter for the 24v heads out of an old socket with a notch cut in it. Rebuilt dozens of m20 heads with it and about half that of 24v heads in the past couple years.
          john@m20guru.com
          Links:
          • whodwho
            • Jun 2008
            • 1547
            Definitely, I have Snap-on plug socket that has a magnet instead of the rubber bit works great :)
            I suppose you could pack it with some wheel bearing grease to catch them as well, might be a bit messy tho...
