welding question.
  • gooseadrian
    • Aug 2011
    • 284
    welding question.
    What are the kinds of welding you guys use in your cars? And what kind of welder would you guys recomend for someone buying on a budget around 200-250? Thank you. Any info is appreciated.
    Fuck you buddy
  • Pantless Spency
    It's McRib time!!!
    • Feb 2011
    • 7283
    i thought i didn't know anything about welding....
    sigh.
    i would imagine most people who ware working on cars would use tig for there aluminum parts and mig for various parts.
    maybe some arch but i don't see that being the best option?
    idk i took a welding class and i sucked ass at welding, did all my homework though.
    • Exodus_2pt0
      • 5943
      If you are just working out of your garage you can get away with a mig from harbor freight.
      One requirement, GAS. Do NOT buy a gasless welder. If you do, it won't matter how good you are, your welds will look like shit.
      Keep your parts to be welded clean with a sanding disk before work begins. Have fun, don't weld in a straight line, make a C and fill it in to start, then another C.
      ---- < welding line. -----C<fillC<fill get my drift?
      No E30 Club
      • Pac1373
        • 1746
        ^ +1, at least buy a "gas ready" wire feed, so you can add on a bottle, I have my Princess Auto special, (HF is about the same) and Have not set up gas yet, spatters like a Mo-Fo.
        Originally Posted by ACMF74
        i clicked on this cuz i saw p3nis
        • slammin.e28
          שמע ישראל
          • 12054
          Craigslist is your friend.
          • InuFaye
            • 2221
            I weld cars together in parking lots.
            1986 Plymouth Horizon. Base.
            • slammin.e28
              שמע ישראל
              • 12054
              Like that early 'vert with a late model tail welded on?
              • InuFaye
                • 2221
                I was thinking of welding a miata to the backend of a 240 in the bed bath and beyond parking lot.
                • slammin.e28
                  שמע ישראל
                  • 12054
                  You won't.
                  • InuFaye
                    • 2221
                    They both have about the same horsepower/weight ratio.
                    So they should rip each other in half if they both drive away at the same time.
                    • slammin.e28
                      שמע ישראל
                      • 12054
                      But if said 240 is the one I know you're talking about, then the engine will give out due to lack of oil and the Miata will drag it so fast across that parking lot, Rue 21 won't know what hit it.
                      • cabriodster87
                        • Jan 2011
                        • 1042
                        I have 4 welders, Century wire feed flux core/gas ready for general mild steel. Miller AEAD 200LE Stick welder W/TIG. Millermatic 130 auto ark wire feed W/aluminum spool. and an old Monster Lincoln pipe line welder (used mainly for power outages at the homestead) I use the century flux core the most, you can get one at Farm and Fleet or the likes for under $200. Stainless and Aluminum the millermatic cant be beat. The AEAD 200LE is gasoline powerd on a custom trailer for the field work.
                        Reich und Roll!
                        • Fusion
                          • Nov 2009
                          • 3659
                          I don't know how to weld but I have been doing some aluminum brazing and that shit's awesome!
                          No more looking for reluctant Al welders.
                          • MikeDE
                            • 1873
                            Just bought an Einhell BT-GW150 wire feed, it was within my budget and is for use with Shielding gas only. Bought a 20L Bottle/tank today filled with 82% Argon/18% C02....not ideal but good enough for practice and what I need to weld at the moment.
                            -03/2005 E46 330D Touring 6spd(204hp/410nM) Sapphire Black/Naturbraun Sport...300k KM & 35mpg(mixed)
                            • mrsleeve
                              • Mar 2005
                              • 16387
                              if you dont know how to weld, and you are asking about what welder (aka process) you use on cars. You should not be welding ON cars until you learn how to weld properly.
                              Originally posted by Fusion
                              William Pitt-
