Home Depot Dremel Tool Kit
  • bmwstephen
    • 2463
    revised.
    want to know which model I should get. Looking to get somethign that can do minor body work such as cutting through bolts, screws, sanding maybe do small detailing work.
    I know some people say I should stick to corded but I'm looking at the specs for cordless and their performance appears to be the same?
  • Swanny
    • Mar 2012
    • 2834
    I have an older dremel. Does fine for the few things I use it for. I don't do a lot of small intricate crafty things mostly as a small grinder and cut off tool.
    I'd grab the harbor freight one cause it's only like 10 bucks. See how that works then move up to a full dremel kit if needed.
    Swanny!
    SUCKERS.
    • 5Toes
      • 9836
      cordless?? ewww
      • bmwstephen
        • 2463
        well ideally i want one that can cut through small bolts. I restore a lot of furniture from time to time and one annoying thing is when people tend to tap screws or bolts onto areas that I need to separate and the best way is to cut straight through them.
        • CrusherCurtis
          • 2532
          DO NOT get the harbor freight one. It is absolutely horrible. I was trying to cut through thin metal and it would just stop turning. Took it back. I know its tempting because authentic Dremel prices are super high.
          Edit: Have to stress it. DO NOT get the harbor freight rotary tool. I'm speaking from experience.
          • AT-JeffT
            • 145
            I've read as a general rule, don't buy anything electrical from HF.
            • bmwstephen
              • 2463
              okay, so I'm sticking with dremel for sure. now home depot offers a variety of kits and honestly, I can barely tell the difference between a dremel 4,000 and 8,000 and the prices are the same.
              any advice on what to look for would be good. again, my main concern is if it can handle light body work. such as metal on metal contact with cutting through bolts and stuff.
              • blackhawkimpact
                • 2415
                I have the Autozone one. Pretty good for $20. Just get the bits from Home Depot because the ones that come with it are very brittle
                • bmwstephen
                  • 2463
                  bump any other opinions on dremel, especiallly waht model to get? looking to make a stop there today
                  • E30_Pare
                    • 7801
                    Harbor frieght is garbage. I have one doesn't work. I really only bought it for the bits anyways. I would invest in a dremel. Worth the money if I your actually going to use it. I've used cheaper mini rotary tools, but nothing really compares to a dremel. Best constructed/reliable off the shelf, and for around 40-70 isn't to expensive
                    DREWLIENTE
                    1$ PShops PM me
                    • E30 331is
                      • Sep 2011
                      • 1166
                      http://the-gadgeteer.com/2009/10/30/...z-lock-review/
                      ^ the 300 is great, anything for more power I use a drill.
                      Sometimes at Lowes or at HD they have the additional bit kits and stuff for 50% off. The Ez lock cutoff tools are great and so are the carbide tips.
                      Otherwise I just buy the tiny drill bits and such from HF.
                      • Kershaw
                        • 11822
                        dont get cordless.
                        dremel (tm) is awesome.
                        AWD > RWD
                        • Farbin Kaiber
                          Lil' Puppet
                          • 29502
                          I got the ~$79.99 Dremel from Lowes, they incorrectly placed the product with a $44.99 price tag, so they gave it to me at that, I made up the difference with a few sets of their accessories. It's great. I also picked up the Blue Point air powered tool, I like it a lot as well for smaller areas.
                          • Jorgen
                            • Aug 2011
                            • 320
                            Do you have an air compressor? I am a fan of tools like this run off air.
                            2011 JGC daily, 1985 944
                            • Jorgen
                              • Aug 2011
                              • 320
                              Hadn't ready that one. that makes 2 fans of air.
