Acceptable and Unacceptable Harbor Freight Tools
  • brianao34
    • Jun 2010
    • 660
    Just thought this might help to collectively weed out stuff you should and shouldn't buy from there, because somethings you just can't screw up.
    Post your experiences.
    Good
    Aluminum floor jacks: I picked up a used one from a yard sale and have used it for 5 years and have had to bleed it time to time and replace the main o-ring once.
    Good
    Impact Sockets: I work at an assembly plant for railroad maintenence equipment and most guys in the shop have HF impact sockets and they hold their own.
    Good
    Spot Weld Cutter: Recently reconstructed the front inner fenderwells on my car and probably drilled out 30-50 or so spot welds before this gave out. well worth the $5.
    Bad
    Step Drill Bits: Garbage, returned it the next day, tried to open up two holes a few steps and I was basically manually pushing it through the last hole.
  • dude8383
    • Jan 2005
    • 10387
    Great thread. Garage journal has a thread too!
    • slammin.e28
      שמע ישראל
      • 12054
      That spot weld cutter. To think, I've been using a drill all this time.
      • series88
        • Nov 2011
        • 1231
        for me so far
        Good:
        *jack
        *jackstands
        *creepers
        *most of their hand tools
        *engine hoist
        *torque wrench
        not too sure
        *zipties
        *some of their drill bits
        *orbital buffer
        Just saying from experience
        • Pac1373
          • 1746
          I hate that feeling you just had, of realization of time spent, tools thrown, blood leaked and pain in the ass suffered.
          been there too...lol
          Iknowhowitfeelsbro.jpeg/
          Originally Posted by ACMF74
          i clicked on this cuz i saw p3nis
          • Nick_S
            • Apr 2011
            • 3655
            BAD
            Metal sheers...garbage, all they did was bend the metal.
            GOOD
            Hard to beat these for the price.
            Ehhh, decent?
            For the money it's hard to beat for the casual mechanic. $18 for the whole set.
            91 318is M50 swapped
            05 Honda Pilot
            24V swap thread
            • brianao34
              • Jun 2010
              • 660
              It's a life changer, the center punch/pin is spring loaded so as soon as you cut through the top sheet metal layer it pushes the layer behind it back a little, if that makes sense.
              • roguetoaster
                • 7775
                Good:
                100 Piece Security Bit Set #68457
                Works just fine, has most every security bit you need for taking apart small items like pressure washers or other things you are not supposed to service.
                5 Piece Slide Hammer and Bearing Puller Set #95987
                Works really nicely on a stubborn pilot bearing! A fine economy slide hammer, but I have questions about its longevity.
                Bad:
                11 Piece Snap Ring Pliers Set #92374
                Worthless, not only do the pliers not stay together, but the metal deforms very easily, making them one use tools.
                1/4" (and the 3/8" + 1/2") Socket Rail #39721
                Not great, bar is rough, hard to slide the holders, and the holders snap easily when you try to remove a socket, which is often not easy. Bolted in place they might be okay, in a tool bag they are terrible.
                5 Piece Front End Service Tool Set #66686
                Worked fine for five ball joint removals (did a good job of not damaging the joint too), then the screw ate up the metal in the largest tool. Further the threads are overly fine, which means you are there forever turning the screw.
                • slammin.e28
                  שמע ישראל
                  • 12054
                  That's brilliant. I've got little holes all over my core support from drilling, etc. Ugh.
                  Sidenote, I've heard their pipe benders are garbage and more like "tube" benders.
                  Any experience?
                  • iamsam
                    • Jun 2008
                    • 173
                    GOOD
                    Low profile floor jack. I got a "bad apple" floor jack, returned it for a direct replacement, and this one has operated flawlessly for months.
                    1000 lb engine stand. At $45 w/ the 20% off coupon, you can't go wrong. Hold up my engines without issue.
                    Any sockets/extensions/adapters, i.e. anything that you can put on a ratchet wrench. I ONLY buy this stuff from HF, I have yet to have one break or fail in any way.
                    This specific style of screwdriver (flat and phillips). Best screwdriver I have ever had, and a steal at $2.
                    Hand sledge. For $8, this thing works great, I always need to bash something on one of my BMWs.
                    Hand wrenches. Never had a failure, and when on sale, less than a dollar per wrench. Can't go wrong there.
                    6" digital calipers. At $10 w/ a sale coupon, these work great and have not failed me yet and remain deadly accurate.
                    In general:
                    Anything from HF is good that is not a power or air tool (with exceptions of course), things like bits, hoses, fittings, hand tools, etc are all great.
                    BAD
                    Air saw. Waste of money, it will barely cut through a sheet of paper without binding.
                    Nitrile gloves. These will disintegrate off of your hands after about ten minutes of handling any sort of oil.
                    • iamsam
                      • Jun 2008
                      • 173
                      OP, maybe you should somehow combine all of our posts into your first post so there is a "one stop shop" for HF tool reviews on R3V. Great thread idea btw.
                      • brianao34
                        • Jun 2010
                        • 660
                        Good
                        Tire Changer: This is PERFECT for removing old tires for shipping purposes or if you have a set of wheels to refinish. I wouldn't trust myself putting a tire on a wheel I have just refinished just because the tire iron is sure to scratch.
                        • slammin.e28
                          שמע ישראל
                          • 12054
                          Pictures are hugeeee too. Any way to resize?
                          • brianao34
                            • Jun 2010
                            • 660
                            They're just embedded off HF's site :/
                            • iamsam
                              • Jun 2008
                              • 173
                              I trued using the small thumbnail images from HF, but apparently they come over full size...
