fxxk my life
  • Dirty325ix
    • Sep 2012
    • 689
    fxxk my life
    Just a little venting here......Well iJust get done with a fluid swap on the whole car....new CV axels....new timing belt...new bearings
    And I'm bleeding my coolant system and I blow the flipping head gasket
    Fuck my life why does god hate me?
    Pretty close to selling this heap of shit ix
  • kickinindian
    • 2327
    ill take it for $3.50.....
    • ak-
      • 12422
      maybe he stopped you from doing something even more stupid upon finishing the bleed
      1991 325iS turbo
      • Kevinl
        • Oct 2012
        • 897
        How did you manage that
        1989 BMW 325is Lachsilber metallic 5 speed
        2007 BMW 335i KARMESINROT 6 Speed manual
        2011 BMW X5 35I
        • e34john
          • Apr 2006
          • 3599
          Atleast it gave out close to home.
          • Dirty325ix
            • Sep 2012
            • 689
            I guess I forgot every step
            I don't know what was wrong with me but I filled the coolant from the reservoir instead of the upper radiator hose and I am thinking there was not enough coolant in the system to circulate or sum shit barly could get any to come out of the bleeder and I didn't notice a problem until water started leaking out of the overflow at the top of the radiator and then just a minute later it starts boiling.....I never even saw it get past the 3/4 mark on the temp gauge
            But i then filled it back up(just topped it off with straight water cause i figured i blew it)
            Kinda hate my self right now not in a great spot to drop $200 on a headgasket kit and to get the head decked
            Uggg this was the fluid change since I did the 5 speed swap and engine reseal
            I'm just retarted
            • Dirty325ix
              • Sep 2012
              • 689
              I cried a little I'm not gonna lie but it was disguised with loud curse words
              • Kevinl
                • Oct 2012
                • 897
                Are you sure its blown did you have the heater on full blast
                I have never had a problem bleeding and never actually used the bleed screw just filled the resevoir and let it run with the cap off and keep topping it off as the air comes out
                How do you even fill from the radiator hose?
                2011 BMW X5 35I
                • deutschman
                  • May 2008
                  • 5958
                  One time I was filling my tire up and my radio cot fire. That sucked
                  • Dirty325ix
                    • Sep 2012
                    • 689
                    Don't jynx me I just redid my 5speed sway wiring
                    I didnt know it could be that easy....i am sitting there with the front jacked up an inch and i am reving the car up while working with the bleed screw
                    i'll definitely check again tomorrow...sadly(maybe that help me sleep)
                    Buy for some reason bleeding my coolant system is impossible for me but before this the car drove perfectly fine for 6 months and never even lost a drop of coolant so I know there wasn't a blown head gasket before this
                    And I bipassed the heater core so I don't turn the heat on
                    I hope I am just retarted
                    I have never taken my car to the shop and have done everything except for rear subframe
                    And for some reason the biggest obstacle's for me are fixing my brake light problem and bleeding my coolant
                    • Kevinl
                      • Oct 2012
                      • 897
                      no heater? doesn't colorado get cold
                      2011 BMW X5 35I
                      • Dirty325ix
                        • Sep 2012
                        • 689
                        Dammit now I kind of have hope this is messing with my head.....hopefully if I do it with the rad cap off, it won't go crazy when a gallon of air tries to rush out of a pin sized hole
                        • deutschman
                          • May 2008
                          • 5958
                          I would be really really surprised if you popped the head gasket while bleeding the coolant. Are you getting white smoke out of the exhaust or any other singes like oil in your coolant overflow tank? If you lived near me Id let you use my head gasket test kit. It just sniffs the air in your radiator and chemically tests if there is any carbon monoxide in it.
                          • Dirty325ix
                            • Sep 2012
                            • 689
                            All of that is definitely good but i didnt know if it would take a while to show those symptoms
                            I may get a jacket and test it with the cap off.
                            And yea its cold as hell out here but I have heated seats!!!!and something broken inbetween my firewall and I can't get that damn thing out so I keep putting it off....still have heater core in the car
                            Some cold drives with all the windows down and the air on full blast so you don't fog up the windows while your driving, having really thought much about that till now haha
                            • Dj Buttchug
                              • Jun 2010
                              • 7688
                              lol op HG is not blown dude.
                              Turbo M42 Build Thread :Here
                              Ig:ryno_pzk
                              I like the tuna here.
                              Originally posted by lambo
