Cabrio battery replacement weight has uses!
  • parkerbink
    • Jun 2004
    • 10138
    I used it yesterday to jack up my Land Cruiser. Works great!
  • trashcop 80s 80s
    • Jun 2004
    • 1130
    does your tile garage floor not crack?
    • 87Blue325iC
      • Apr 2006
      • 1111
      Did you take it out for good? How does the car drive without it?
      Aaron
      • ToplessE30
        • 4791
        Mine drove much better. I think it was because one of the mounting points failed... so it moved around a lot.
        Estoril E36 M3/4/5 | Toledo E53 X5 3.0 | LeMans E90 335D M-Sport
        • parkerbink
          • Jun 2004
          • 10138
          Car drove fine without it, I am not sure why BMW decided to put a 50lb block of metal in the trunk.
          • Digitalwave
            is a poseur
            • 6293
            Balance, balance, balance. The people that remove the trunk slab from their cars and leave everything on the front make me laugh. The cars already have a front bias!
            RISING EDGE
            • DEV0 E30
              • Oct 2004
              • 8877
              Your mom has front bias. Ooooooh.
              • Jordan325iC
                • Aug 2005
                • 1697
                Well, it takes about 30 seconds and it lowers the car's weight by ~2%. Who honestly drives their car so hard on the street that you can tell if 50lbs dropped from the trunk?
                Although I personally plan on moving my battery back there when I lose my A/C.
                '88 325is
                VP UT of Austin Autoholics
                BMWCCA 380364
                • Digitalwave
                  is a poseur
                  • 6293
                  Oh shit, he did not!!
                  RISING EDGE
                  • parkerbink
                    • Jun 2004
                    • 10138
                    How do you figure? in non cabs there is no weight in front where the battery is, is there? No battery in the front of those cars right?
                    The cab is heavier as it is. I drove mine at 8/10ths on Mulholland without the weight and it handled great.
                    Have you driven a cab with and without this weight TJ?
                    • delphini
                      • Apr 2006
                      • 680
                      i'm not a know-it all but as soon as i removed mine i could tell an instant difference. b.t.w the mounting brackets that hold this piece in had long ago
                      broke and the "weight" was sorta flopping around on its mount.
                      :pimp:
                      • Dave
                        E30 RAT
                        • 11675
                        I still have mine laying in the garage - have yet to find a use for it.
                        Current Cars
                        2014 M235i
                        2009 R56 Cooper S
                        1998 M3
                        1997 M3
                        • parkerbink
                          • Jun 2004
                          • 10138
                          Until I used it to jack up my truck it was sitting under my oil removal receptical, identical to the one in your sig picture Dave. Kept the dribble off the floor.
                          Try it next time you jack something taller than an e30, works great to increase the lift and footprint of the jack.
                          • delphini
                            • Apr 2006
                            • 680
                            Mine wasn't painted and it had FRUDENBURG stamped on it .
                            :pimp:
                            • 2002maniac
                              • 4260
                              who cares? 50/50 weight distrubution doesnt mean much. The suspension can be adjusted and tuned as needed.
                              50lbs in a cabrio is rather insignificant though.
