How about a Low CR Destroker?
  • Kershaw
    • 11822
    CR 3.5-4:1
    Crank 65.3
    Rods 35
    Pistons - stock
    Stock 731 head
    valves - stock size but oval valve shape
    BBC
    84 mm bore
    camshaft - Gallo 24
    Gallo 12 valve springs
    Stamped steel cam gear
    no oil pump
    no starter
    m42 dual mass flywheel
    SACHS Performance sport Clutch
    IE slim rocker arms
    I'm thinking because it's destroked and low compression it'll r3v really fast and my RPMs can be over 9000.
    AWD > RWD
  • ak-
    • 12422
    You'll need to delete the intake
    1991 325iS turbo
    • Kershaw
      • 11822
      I think you're wrong and everything you say is wrong and your dad is probably wrong too.
      I'M THE ONLY EXPERT ON R3V!
      AWD > RWD
      • decay
        • 5637
        it'll be the longest-lasting lawnmower engine ever
        past:
        1989 325is (learner shitbox)
        1986 325e (turbo dorito)
        1991 318ic (5-lug ITB)
        1985 323i baur
        current:
        • MrBurgundy
          R3V Degenerate
          • Mar 2012
          • 5588
          You gotta stack 6 head gaskets and do a 1.3 to 1.1 swap
          • LateFan
            • May 2013
            • 4407
            Well played Mr Kershaw.
            • LJ851
              • 7919
              BBC really seals the deal on this epic power plant. And the oval valves.
              Lorin
              The M30 is God's engine.
              • flyboyx
                • 8371
                Big Black C--K?
                Gigitty Gigitty!!!!
                • mrsleeve
                  • Mar 2005
                  • 16387
                  I feel like I have missed something important
                  Originally posted by Fusion
                  William Pitt-
                  • LJ851
                    • 7919
                    Lorin
                    • ThatOneEuroE30
                      • Dec 2013
                      • 8626
                      Well played kershaw. Well played.
                      1991 318i 4dr slick top
                      Mtech 2 turbo restoration
                      • IceWhite
                        • Jan 2015
                        • 945
                        This won't look stock, but I am sure it will let you sleep on the side of the road!
                        Ah. What do I know, carry on!
                        1990 325i
                        2004 330i Individual 6-speed
                        • TimeMachinE30
                          • Jun 2014
                          • 3749
                          New idea: swap in a Briggs snd Straton.
                          ACS S3 Build / Dinan 5 E34
                          • flyboyx
                            • 8371
                            Ah....it all makes sense now. Pretty unbelievable actually. Lol. Too bad I didn’t see this in time to fuck with him a little.
                            I think “we” forgot to mention the “cumshaft”?
                            Gigitty Gigitty!!!!
                            • roguetoaster
                              Biggus Tippus
                              • 7830
                              Would it be variable lift and duration?
