Went drag racin y'all
  • Stu Mc
    • 4083
    I went to the local 1/8 mile with a guy from work to compare his 3.0 m20 to my 3.0 m50. My M50 was a bit faster, but on such a short track you really don't get any speed built, 1st through most of 3rd gear and that's all.
    He launched his car, however, I just let the clutch out and floored it on all my runs. My best was 9.05, his was about 9.8, and only about 6-7mph shy at the end. His daughter actually got her stock 325i to a 10.0, which is pretty damn good.
    Here's one of me getting raped by a turbo Neon with drag tires and plenty of hp.
    Thanks to the guys at www.CheapTriXRacing.com for taking a video of my run.
  • gstuning
    • 833
    how much are you making powerwise??
    my S50 best is 8.4 :)
    Gunni
    @ Prodrive / Aston Martin Racing
    • Il Duce
      Non-Mod M42 Modder
      • 5046
      i have to go s50. thanks for the inspiration.
      • AdironRider
        • Dec 2004
        • 3491
        Trying to be modest calling it an m50 stu?
        Back to my roots
        • Stu Mc
          • 4083
          My last visit to the strip, on the stock M3 clutch, with slipping it from about 2500rpm and stickier rubber, best run was 8.5xx at 83mph. That clutch wore out pretty damn quick, so I don't slip/drop it anymore with the new clutch.
          GSTuning, the 8.4s that you ran is what most E46 M3's run!
          How much horsepower is your Euro motor making?
          Fife--well, it did start as a 525i block and 528i head. :) Just happens to have a 3.0 rotating assembly and full M3 valvetrain.
          • FredK
            • 14762
            Stu, when you bored the block to 86mm did you use a torque plate?
            • Stu Mc
              • 4083
              Fred, I don't believe so
              • Bill 84 318i
                • 1600
                Nice, what was your 60'? The 9.0x is the same 1/8 mile that I put down in my STi (at only 75mph), but I still haven't gotten the launch down (and I've quit trying...poor clutch).
                • gstuning
                  • 833
                  The motor was dynoed 244rwhp and 242lbs torque at the flywheel,
                  god I miss that thing, the most awesome engine sound I have heard live
                  Gunni
                  • mtechnik
                    • 6156
                    thnx for sharing ur vid :thumbs:
                    Would be great if you had one of you vs ur colleagues M20 3.0
                    • aaron.j
                      • Jan 2006
                      • 529
                      Did he have an anchor tied to the m20 car? I ran a 9.6 in a 2.5I u.s. spec engine in a euro car.
                      • ColdAccord
                        • 5926
                        ungh i want to go euro s50 in my car but I'm gonna hold off. if i get this euro 320i touring its definately getting a euro s50. it would be right at home
                        Originally posted by blunt
                        • Mitch M
                          • 881
                          Re:
                          What were the trap speeds for the 330' (if the track has it) and 660' (1/8 mile) for both cars? Great estimator of power and helps eliminate the driver.
                          • Stu Mc
                            • 4083
                            Mitch, I can check my timeslip when I get back to Charlotte. I do not know if Bill (3.0 m20) kept his timeslip.
                            I forgot to mention, his car has a bad 2nd gear syncro. He shifted out of 1st at 5500 rpm's, which seriously hindered his times. I suspect that if he would have buzzed it 7200 in 1st, he would have been in the low 9's.
                            I realy wish we had a 1/4 mile track close by, I'd like to be able to stretch out 4th gear. This 1/8 mile, you can have very little horsepower but if you get a good launch, you'll almost inevitably get a good time.
                            Aaron, that's a good time. You must have gotten a hell of a launch; what did the car weigh? 4.10 rear gear?
                            • CleanAzzE30z
                              • Jan 2004
                              • 11794
                              Whats up STU!?!?!? Hows your brosef?? nice to see you around man. :) Man I remember your bro and yourself are literally some of the first people I ever met (online or otherwise) that had to do with BMWs back in '99-'00.
                              Mariano
