name them problems
  • featuring france
    • Jul 2005
    • 368
    name them problems
    everybody's had problems with their e30...name em all from first to most recent. I'll start.
    my 84 318i
    1. a major oil leak
    2. guibo ripped to shit
    3. drive shaft went bad
    4 diff brace mount holes ripped from diffs
    5. gear diff went bad
    6. rim just recently bent
    7. alternator went bad
    8. battery needs to be replaced
    9. oil still leaks
    10. wen i hit 75, the car vibrates
    11. car needs fresh paint
  • mtechnik
    • 6156
    1. AFM went bad
    2. Battery died
    3. Tires wore out :razz:
    4. Driver-side shock blew (KONI'S went in yo!)
    5. Speedo signal went out
    6. Oil pan gasket going bad :sad: & no money right now for that job!
    • 92 mtechnic cabrio
      • 4907
      all the way from beginning?! that would require too much thinking and the list would be at least one hundred items long, no joke. Maybe I will do it later today after I've gotten some rest.
      R.I.P 07/01/09 - 04/23/10 :(
      • matte30is
        • 97
        BMtroubleshoot.
        shocks/springs
        rear diff
        rear brake rotors
        front brake rotors
        alternator
        all suspension bushings to polyurethane
        control arms
        tie rods
        driveshaft
        muffler
        new paint
        front lip
        clutch slave cylinder
        brake lines to S.S.
        removed power steering pump
        I'm sure there is more......
        88 325is. 4.10 lsd, J.C. chip.
        • StereoInstaller1
          GAS
          • 22679
          1. Shifter so sloppy it is hard to tell 1st from 4th
          2. Smokes like a french whore
          3. Drivers window regulator
          4. Clunk from rear: SFBs?
          5. NOISY valves
          7. Nasty carpet
          8. Water leaks
          9. Oil Leaks
          10. PAINT
          I don't even count little shit like the door panel mounting snaps being fukzord or the squeaky seats, the dents, swaybar issues, OBC lightbulbs being out, on and on.
          On the plus: I fired her up yesterday to go get it buffed. No taillights for two weeks (due to droppage, oopsie!). Raspy and rowdy as fuck, about 30 degrees outside. Just rolling across the parking lot the damn thing smoked the tires and got all sideways...like the little bitch it is.
          Sweetly drive all nice and proper? Fuck no, you will get stranded.
          Thrash the piss out of her, drive like it is a grudge-fuck...she smiles and says "More, Daddy?"
          Every day someone comes into my shop and comments on what a "hot little car that is"...ev3ry day. If it were as nice as some on this board I would walk around with an erection all day.
          Luke
          Closing SOON!
          Thanks for 10 years of fun!
          • JGood
            • Jan 2004
            • 7959
            oh man. I wouldn't even know where to start. I have service records from the day the car was bought by my step-aunt. ~$23,000 for the car in 1985. ~$21,000 worth of service history from the dealer. I bought it in 2000 and have put ~$15,000 into it since. A good $10,000 of my spending was mods, but I saved a good $8,000-$10,000 on normal maintanence/repair by doing work myself and taking all the parts from my own parts cars.
            The only thing on my car that is untouched is the engine internals.
            The one thing that pisses me off about my car because I replace 1 a month:
            Door handle surrounds. Honestly, WTF?!?! Those plastic rectangle rings of shit can go to hell.
            e30 restoration and V8 swap
            24 Hours of Lemons e30 build
            • Garageaholic
              Freestyle Fabricator
              • Dec 2005
              • 5204
              Rusted rear window motor
              bad reference sensor
              washer wiper fluid sensor failed
              Humming in the rear of car (bearing)
              headlight leveling
              Re-wire wiper motor loose connection
              Recent Rebranding!!
              E30 SM62/S62
              E30 M60 V8
              E30 M30 Big 6!
              Instagram.com/garageaholic
              Youtube.com/garageaholic
              • dvs909
                • Sep 2006
                • 1149
                Driver.
                I had a ID10T error
                ________
                Launch Box Vaporizer
                • JGood
                  • Jan 2004
                  • 7959
                  Originally posted by dvs909
                  Driver.
                  I had a ID10T error
                  Yes, alot of times the PEBWAS.
                  • uofom3
                    • Jan 2004
                    • 5392
                    -Paint
                    -rear subframe bushings(have)
                    -diff cover/gasket/bushing
                    -central lock system
                    -brake master cyliner (have)
                    -time and decent weather to complete the projects
                    PNW Crew
                    90 m3
                    06 m5
                    • Mike325
                      • Mar 2006
                      • 3685
                      Most of this stuff did not need to be changed, I did them because I was in there and it was the perfect time to do them.
                      Stuff that I replaced as normal wear items as well as broken parts are....
                      SFB
                      TAB
                      CAB and control arms
                      All the suspension
                      Every brake componant
                      Flex disk
                      Gas tank
                      Thats kinda all for now. I have a shit load more stuff that was changed for upgrading purposes.
                      Originally posted by Kershaw
                      • jhower08
                        • Jan 2005
                        • 494
                        thats pretty bad
                        • Il Duce
                          Non-Mod M42 Modder
                          • 5046
                          lack of existance.
                          • eurostyl e30
                            • Dec 2005
                            • 554
                            New shocks and springs
                            New guibo and CSB (torn like all getout)
                            OBC light bar and various interior bulbs
                            Coolant level sensor
                            ABS sensor
                            I've gotta do my control arms/CABs soon.
                            • JPL
                              • May 2005
                              • 774
                              uh.....
                              broken side view mirror
                              broken stock radio & rear speakers
                              timing belt/tensioner/water pump
                              coolant level sensor
                              new tire (does a tire count?)
                              new guibo
                              steering rack-leaks
                              oil pan gasket-leaks
                              now that i look at the list i've made of things that i had to replace, i think i've had it pretty good.
                              Originally posted by Hawt drift chick
                              Yeah, i'm a good dude i swear, i just like to be balls to the wall.
