Gun Thread
  • Wschnitz
    • 8089
    #7096
    Saw this on MAC:
    I kinda want one in two tone FDE like a SCAR
    $2k tho lol might as well buy a SCAR
    willschnitz
    • DER E30
      • Sep 2013
      • 2346
      #7097
      I'm a little confused as to what you're doing now. You have the colt which is waiting on SBR paper work and now have the spikes lower set up as a 300 pistol.
      Are you saying you want to put the 300 upper on the colt as the SBR but the colt is rattly with that particular upper? Then you want to take the colt upper and cut it down so you'll have a 556 and 300 SBR uppers? And also build a new upper for SPR?
      -Christian
      • Exodus_2pt0
        • 5943
        #7098
        Yea I'm all over the place.
        So the 300 upper is going on the Colt once I get permission. Of course I can't test fit that upper on the Colt. However, the Colt upper is also sloppy on the Spikes lower, but locks up tight on the Colt lower. It's my assumption that the 300 upper will lock up tight on the Colt lower as well.
        I did toss around the idea of cutting down the Colt, but have ultimately decided against it. The Colt has a very good barrel, so I'm tossing the idea of reassembling it into a matched receiver set to get back the tightness I had with it originally.
        In hindsight, I should have just bought a new quality lower and Form 1'd that.
        No E30 Club
        • DER E30
          • Sep 2013
          • 2346
          #7099
          I think you can get a screw that is the same size as the grip screw for more tightness? Or even something like some tape to make it a bit tighter?
          edit: stick a small O ring on the front lug, then reassemble
          -Christian
          • Exodus_2pt0
            • 5943
            #7100
            I have been looking into the nylon headed screw. I'm comfortable with drilling and tapping the lower. Honestly that is probably the best bet, because it will still be a good old trusty 6920, just with a different lower.
            Then I would be free to just build an entire new rifle without convoluting everything so much.
            No E30 Club
            • DER E30
              • Sep 2013
              • 2346
              #7101
              UPPER RECEIVER TENSIONING SCREW FOR AR15 RECEIVER Replacement 1/4-28 TPI Nylon Tip upper receiver tensioning screw for our T15 and T15BDX AR15 style lower receivers.   A 1/8" allen wrench (not included) is required for installation and adjustment. Note: Two ar
              $1.50 fix
              -Christian
              • Exodus_2pt0
                • 5943
                #7102
                Consider it done. You da man.
                No E30 Club
                • Turbojunkie
                  • Oct 2015
                  • 19
                  #7103
                  Originally posted by e30onBBSs
                  What do you do? ^
                  LEO in Ohio, former competition shooter in both handgun and rifle.
                  • Exodus_2pt0
                    • 5943
                    #7104
                    Took a feeler gauge to the pistol. .005 clearance, well within the .020 limit. I'm beginning to think it might just be the pins that came in the cheap PSA parts kit.
                    Thoughts? Other than the fact that I'm literally bitching about a complete non-issue at this point.
                    No E30 Club
                    • DER E30
                      • Sep 2013
                      • 2346
                      #7105
                      It may be a non issue, but if it makes you feel better then fix it!
                      I have a set of pins kicking around from the -10's lpk, pm me your address, I'll drop them in an envelope tomorrow.
                      -Christian
                      • Exodus_2pt0
                        • 5943
                        #7106
                        Doesn't the ar10 use different pins?
                        I had a "duh" moment the other day. Needed a crush washer to proper affix my SDTactical brake (form 1 pending, going with a diy titanium .308/5.56 can). So I went to my LGS, bought 3 just because.
                        Got home, realized I grabbed 1/2" instead of 5/8. Oh well, at least now I have them for when I purchase a brake for the Colt.
                        No E30 Club
                        • DER E30
                          • Sep 2013
                          • 2346
                          #7107
                          Yes, but the Mega included pins and uses a 15 lower parts kit and it was cheaper to get a whole lpk vs ordering the individual parts so I have a set as spare. They're PSA but they might be a bit different than yours
                          -Christian
                          • Exodus_2pt0
                            • 5943
                            #7108
                            Worth a shot, PM inbound!
                            No E30 Club
                            • Exodus_2pt0
                              • 5943
                              #7109
                              Watch out, brace users.
                              Also, anyone want this? Looking to get $40 shipped for it.
                              5/8-24 3 chamber POF brake. Paid $60 for it, only put 40 rounds through.
                              Slight blemish on the lock ring.
                              No E30 Club
                              • Wschnitz
                                • 8089
                                #7110
                                I tried looking at AR stuff instead of AK stuff and I just get lost in all the options.
                                willschnitz
