Minimalism at its finest...
  • Kruzen
    • Mar 2004
    • 5603
    Command line video editing, courtesy of ffmpeg for windows and python25 ;)
    each ripped dvd/avi is paired with a text file containing time codes for each movie (which are pre-determined scenes to be edited out).
    The python script reads through the text file, looks for the AVI file with a matching name, and then runs an ffmpeg command line which grabs that section of the AVI and re-encodes it as its own AVI file. Easy peasy japanesie. hours saved? ~20 on this portion of the project, roughly 60 hours total by the time i'm done. Much much easier than manually cutting each scene out using premiere, etc.
    Who doesn't love a little BBQ?
    Griot's Garage at a Deep Discount
  • ///Mayhew
    • May 2007
    • 285
    wow you just confused the hell out of me. I am computer retarded.
    1989 325i MT2/4dr
    My life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather i will skid in broadside,thoroughly used up,totally worn out and loudly proclaiming....WOW..What a ride!
    • cferb
      • 1442
      +1, I wouldn't call myself computer retarded, but, I didn't understand a word of that
      • JGood
        • Jan 2004
        • 7959
        hahaha i like how your cpu has been pegged at 100% usage for who knows how long. So, why are you trying to get certain clips out of the movies? Or did I misunderstand what you are doing?
        e30 restoration and V8 swap
        24 Hours of Lemons e30 build
        • Farbin Kaiber
          Lil' Puppet
          • 29502
          Sandlot. L7 Weenie. I could not figure what you could be cutting out of that random list of films.
          • Jon325i
            • 6934
            Do I understand what he's doing? Yes.
            Do I know how to do what he's doing? Hell no.
            Good job man :up:
            Jon
            Rides...
            1991 325i - sold :(
            2004 2WD Frontier King Cab
            RIP #17 Jules Bianchi
            • Kruzen
              • Mar 2004
              • 5603
              I'm cutting out clips from movies which obey the Fair Use requirements for educational media editing. Basically i'm compiling a dvd for teachers to use in the classroom to supplement some material they have. The dvd contains small clips from different movies to enforce different characteristics or values or some bullshit, so this saves them time from seeking to scenes on a bunch of dvd's. I haven't the damndest idea why they picked these clips, but these are the movies and clips i've been given.
              • Jean
                • 18228
                Lol at ffmpeg :) I don't know how to use python, don't you still have to find the start/end times for the scenes you want to cut out ? Are you inputting them in python or something ?
                • Kruzen
                  • Mar 2004
                  • 5603
                  Python is a programming language :) And I didn't have to find the start/end times, they were given to me (this is for my job).
                  This is what makes up 'cutme.py' http://en.wikipedia.org/wiki/Python_...ng_language%29 fo more information about python. Its just a short script that will pull the timecodes from the text files, look for a avi matched with the same name, and then pull those scenes, reincode them and save them as a new avi in the directory.
                  Code:
                  import os.path
                  import subprocess
                  import sys
                  def timecode_to_sec(tc):
                      >>> timecode_to_sec('10') == 10
                      True
                      >>> timecode_to_sec('3:10') == 190
                      True
                      >>> timecode_to_sec('1:10:10') == 4210
                      True
                      result = 0
                      values = tc.split(':')
                      values.reverse()
                      for i in range(0, len(values)):
                          result += int(values[i]) * (60 ** i)
                      return result
                  def run():
                      file = open(sys.argv[1])
                      clips = []
                      for line in file:
                          if line.strip() == '':
                              continue
                          clips.append(line.split(' ', 1))
                      file.close()
                      # this is stupid but i'm lazy
                      input_file = os.path.splitext(sys.argv[1])[0] + '.avi'
                      input_filename = os.path.splitext(input_file)
                      for clip in clips:
                          duration = timecode_to_sec(clip[1]) - timecode_to_sec(clip[0])
                          args = {
                              'seek': timecode_to_sec(clip[0]),
                              'duration': duration,
                              'input': input_file,
                              'output': '%s_%s-%s%s' % (input_filename[0],
                                                        clip[0].replace(':', '_').strip(),
                                                        clip[1].replace(':', '_').strip(),
                                                        input_filename[1])
                          cmd = 'ffmpeg -sameq -ss %(seek)s -t %(duration)d -i %(input)s -async 2 %(output)s' % args
                          subprocess.call(cmd)
                  if __name__ == '__main__':
                      import doctest
                      doctest.testmod()
                      run()
                  • equate975
                    • Jun 2004
                    • 3382
                    Yeah I understand it, but I didn't understand why until you posted its for class.
                    FYI, the little line in the top right corner lets you "minimize" them all ;)
                    Rollin' with a Geistkuchen
                    • schmidty
                      • 1253
                      haha, best comment ever
                      • Jordan325iC
                        • Aug 2005
                        • 1697
                        I love python.
                        '88 325is
                        VP UT of Austin Autoholics
                        BMWCCA 380364
                        • delatlanta1281
                          Dart Master
                          • Mar 2006
                          • 10317
                          Ummmmmmmm
                          I don't like what you're doing.
                          I don't understand it therefore I fear it and must come kill you.
                          sorry
                          Yours truly,
                          Rich
                          you kids get off my lawn.....
                          • george graves
                            • 19996
                            You need dual monitors....
                            Originally posted by Matt-B
                            • Kruzen
                              • Mar 2004
                              • 5603
                              Meh, at home its a 22" CRT, my desk is too small for two :(
                              Here at work though is a 24" widescreen dell which suffices.
