Siphoning gas?
  • e30Matt
    • 5077
    Siphoning gas?
    My E30's going to be parked for a little while and rather than waste the full tank of gas that's in it (I filled up right before the driveshaft let go) I want to use it in another vehicle I'll be driving.
    Here's the problem... my roommate has a siphon, I crammed 6 feet of tubing down the filler neck to find it bone dry... does the E30 have an anti-siphon setup or something? I know for a fact the tank is full.
    If this won't work, what ways do I have of emptying the tank besides running the fuel pump and dumping the feed line in a gas can?
  • Jonathan M3
    • 1837
    There is a drain on the tank.
    '05 E46 M3 Imolarot/Cinnamon - CURRENT
    '98 E36 M3 Estorilblau/Dove - SOLD
    '90 E30 M3 Brilliantrot/Black - SOLD
    SRS BSNS Motorsports - 24hrs of LeMons Racer
    • Turf1600
      • 9815
      I've gravity-fed all the gas out before - no problems.
      • DarkWing6
        • Apr 2004
        • 7144
        pull the fuel pump from under the rear seat and do it from there
          • 34844
          the drain plug is probably the easiest and least messy way - plus, I wouldn't drain all of it out depending on how long it's going to sit.
          • Joe318is
            • Sep 2005
            • 6451
            you have obviously never done this before.
            Get a tube, stick it in the filler neck and suck until it comes out. The drop the end into a bucket/tank/whatever. be sure to have a chaser on hand.
            Kinda on topic.... anyone know of a locking gas cap that will fit the e30?
            Originally posted by vlad
              • 34844
              uh, yes I have in fact. I don't really enjoy the smell of gas in my interior, either.
              • equate975
                • Jun 2004
                • 3382
                Theres a drain plug??? I have never seen it. I'm going to drain the gas out of the M tomorrow. Is it pretty self explanatory to find? Or is it all hidden away?
                Edit:
                Another idea if the gas isn't bad, you can just pull the line off the fuel pump and jump the relay, then pump it all into a tank. Shouldn't be too messy
                Rollin' with a Geistkuchen
                • TwoJ's
                  • Oct 2005
                  • 4908
                  I don't know of a locking gas cap, but why should you need one? Your filler door locks...
                  • Restoman
                    • Jun 2006
                    • 1311
                    I wouldn't need a brass wrench or anything while dealing with the bolt would I? I get very skiddish around gas.
                    i'lldoitforacaravan
                    • Jonathan M3
                      • 1837
                      Edit:
                      Passenger side, might be somewhat covered with undercoating/dirt.
                      • george graves
                        • 20003
                        Do your self a favor, do this outside and not in garage with a pilot light, or a house to burn down.
                        Originally posted by Matt-B
                        • Julien
                          • 7471
                          joe: euro e30s came with them.. i'm sure your stealer can get you one (non lock is only 6$... locking can't be that much more)
                          Julien
                          Build Threads:
                          • Joe318is
                            • Sep 2005
                            • 6451
                            Im not dumb enough to take the fuel pump out.
                            Ive done this before a couple of times. It makes a huge mess if you are not on your toes when the plug is removed. And it is more difficult to swap cans than the way i suggested.
                            That dosent last 20 years on a good number of cars, and some E30s didnt come with central locking and locking fuel doors.
                            • Joe318is
                              • Sep 2005
                              • 6451
                              Julien
                              Think i found the part numbers through ETK
                              16121178534 and 51212291901
