Impact driver question for mechanics
  • parkerbink
    • Jun 2004
    • 10137
    I have been wrestling with the impact gun issue because I am getting ready to do headers, suspension, crank pulley etc. and figure getting some tools is cheaper then paying someone.
    I have an Ingersoll Rand D650 1/2" Cordless Drill/Driver 19.2V which uses the same lithium ion battery as the Ingersoll Rand W360 1/2" Square Drive Cordless Impact driver.
    These are it's specs. Do they look strong enough or do I need a compressor & air driver?
    Pound for pound, the W360 is the most powerful cordless Impact tool in the world. Patent-pending IQv technology provides maximum performance, durability, and battery life. Compatible with both the 19.2V lithium-ion (BL192) and 19.2V nickel cadmium (N192) batteries. The IQv Series is ideal for mobile service, automotive, tire lane, off-highway, industrial facilities maintenance, and production applications.
    Features: Ingersoll Rand W360 1/2" Square Drive Cordless Impact
    * 360 ft.-lbs. max reverse torque
    * Less than 6.2 lbs. with lithium-ion battery
    * 1,650 RPM, 2,200 BPM
    * Engineered composite housing with patent pending metal subframe for unbreakable strength
    * All metal hammercase and housing ring for added durability
    Specifications: Ingersoll Rand W360 1/2" Square Drive Cordless Impact
    * Max Torque Reverse -- 360 ft-lbs (488.1Nm)
    * Speed -- 0-1,650 BPM -- 0-2,200
    * Length -- 8.9 in. (227mm)
    * Sound dBA -- 90
    * Vibration -- 5.6 m/s2
    * Voltage -- 19.2
    * Usable Torque Range -- 25-280 ft-lbs (33.9-379.6Nm)
    * Tool Weight -- 4.8 lbs (2.2kg)
    * Weight w/ Li-ion -- 6.2 lbs (2.8kg)
    * Weight w/ Ni-Cd -- 6.7 lbs (3.1kg)
  • der affe
    Technical
    • Dec 2005
    • 8452
    i had a snap-on 1/2" impact similar to that one (prob the same) i thought it was a little bit akwards to use under the car. i ended up selling to someone else at work and buying this insted
    it is the way to go if you go for an air powered one
    i also have this one for my 3/8"
    • parkerbink
      • Jun 2004
      • 10137
      Outside the battery awkwardness is the torque sufficient for tough bolts?
      Thanks.
      • Farbin Kaiber
        Lil' Puppet
        • 29502
        I have a Mac Tools Cordless 19.2v 1/2" Peice of Shit. It came in a set with a 19.2v Mac Tools Cordless Drill Peice of Shit. I wouldn't suggest them to Matthew Mayhem. I wish I could have tricked someone into buying them from me. After two trips to warranty repairs they still will not twist a toothpick in butter.
        This is not a buy off the net tool. You need some hands on usage to make sure it's gonna suit your needs.
        • der affe
          Technical
          • Dec 2005
          • 8452
          the torque was pretty good one my snap-on, but the outside battery thing was a pain and it was way bigger so i couldn't fit it into tight spaces very well and i got tired of building extensions/wobbles etc to make it work for me. it worked well for taking wheels off in the lot where i couldn't run an air hose to the car, but that was about it.
          • parkerbink
            • Jun 2004
            • 10137
            I have a compressor & tools in L.A. & Mexico, I don't want or need another. I thought since the batteries are interchangeable (and expensive, the L.I. is 100.00) and I could use the driver as an emergency wheel changing tool if it will work for the header then I can rationalize getting it.
            I am still on the fence. I'll either find someone in Phoenix to do it or wait until I go to L.A. next month.
            • NC325iC
              • Mar 2004
              • 6565
              i have a dewalt 3/8" cordless impact that i use for EVERYTHING, i love it, definitely one of the best buys ive made, that accompanied with a torque wrench good sockets and a breaker bar are all you need
              • mentaleeill
                • 850
                my brother has that I.R. 1/2" impact. hands down the best cordless/ airless impact i have used. way better than the snap on and mac. we use it on his racecar at the track, because it's hard to get a compressor running with the power draw when the pits are fulll of everyone's trailer setups. it has never let us down.
                • allwheeldrive
                  • Jan 2008
                  • 272
                  The great equalizer is rust if you have to deal with it. If not, you are golden.
                  • Rigmaster
                    • 3464
                    You can do all the jobs you mentioned just as easily WITHOUT impact/air tools.
                    That said, if the tool really does generate 360 ft/lb of torque in reverse, then you should have no problem getting any of those fasteners off- you might break them though if you're not careful.
                    • parkerbink
                      • Jun 2004
                      • 10137
                      Thanks for the info guys.
