Gas leak exception to the 4th Amendment.
  • Vedubin01
    • Jun 2006
    • 5852
    Main Street and Canal Street are among the areas affected. Not only are those streets filled with homeowners, but businesses are also impacted by the issue.
    "It’s going to be devastating to be without heat or power for this holiday season. It’s our crunch, time," said Molly Silva, a business owner.
    If no one is home at the time, police officers along with a locksmith are entering homes to shut the valves off.
    WTF?
    http://www.wpri.com/dpp/news/local_n...ing-1600-homes
  • LBJefferies
    • Sep 2009
    • 1690
    It sucks but should they just let 1600 houses go up in flames?
    • mrsleeve
      • Mar 2005
      • 16386
      ummm Like most municipal water, systems gas services, there is a shut off valve at the street or the meeter is on the out side of the home. Sounds fishy to me
      Originally posted by Fusion
      William Pitt-
      • Cabriolet
        • 9620
        the home owner do not own the meters or the gas lines. there for since the owner's (gas co) gave permission it's not breaking the 4th amendment.
        Much wow
        I hate 4 doors
        • Vedubin01
          • Jun 2006
          • 5852
          This is the correct answer. They can cut off the gas from outside your house. There is no need to enter ones house to turn off the gas from the house.
          Very fishy
          • joshh
            • Aug 2004
            • 6195
            This
            "I cannot undertake to lay my finger on that article of the Constitution which granted a right to Congress of expending, on objects of benevolence, the money of their constituents. Charity is no part of the legislative duty of the [federal] government." ~ James Madison
            ‎"If you've got a business, you didn't build that. Somebody else made that happen" Barack Obama
            • Eecen
              • Jun 2010
              • 1235
              Apparently these meters are inside the houses...? Fuck you guys are kind of over the top sometimes.
              Anybody remember that big ass explosion in California awhile back?
              And that is a very poorly written article....
              technicians are continuing to work on a natural gas outage in Westerly and that some restorations will be made overnight Thursday into Friday morning.
              70 technicians will be working through the overnight hours to turn gas back on, and starting at 5 a.m. Friday 200 technicians will again be going door to door to continue making restorations.
              then at the bottom
              If no one is home at the time, police officers along with a locksmith have been entering homes to shut the valves off.
              What now?
              • mrsleeve
                • Mar 2005
                • 16386
                I know what I am talking about worked in the business for the last 18 years. You can shut the gas service off out side the home period never seen a service with out an outside shut off
                William Pitt-
                • Eecen
                  • Jun 2010
                  • 1235
                  Oh no, I'm not saying you're wrong. I went to school to be a Civil Engineer. I have a loose understanding of how the things work (mostly dicking around on CAD doing building/house/lot plans) and those valves are generally outside the house.
                  • Farbin Kaiber
                    Lil' Puppet
                    • 29502
                    You all know how much easier this would all be if the Fire Department already had keys to your doors.
                    • mrsleeve
                      • Mar 2005
                      • 16386
                      I See what you did there.
                      William Pitt-
                      • mrsleeve
                        • Mar 2005
                        • 16386
                        Oh and that big explosion in CA was a 30" or 36" ( I dont remember which) High pressure TRANSMISSION owned by PG&E (of erin brockivich Sp. Fame) line not a low pressure distribution line. It was put in, in the mid 70's (76 IIRC) and was in a very rural area at that time. There was an odd section of line pipe in there that was put together rather poorly even for the time, more than likely to make a bad tie in work. Also IIRC it was the long seam weld, of the pipe that let go not a line weld or the metallurgy of the pipe itself
                        William Pitt-
                        • Vedubin01
                          • Jun 2006
                          • 5852
                          Oh and that big explosion in CA was a 30" or 36" ( I dont remember which) High pressure TRANSMISSION owned by PG&E (of erin brockivich Sp. Fame) line not a low pressure distribution line. It was put in, in the mid 70's (76 IIRC) and was in a very rural area at that time. There was an odd section of line pipe in there that was put together rather poorly even for the time, more than likely to make a bad tie in work. Also IIRC it was the long seam of the pipe that let go not a line weld or the metallurgy of the pipe itself
                          Damn son, you beat me to it...
                          Not a main line that runs from the street to your house with a cut off valve between the two - outside your home.
                          • mrsleeve
                            • Mar 2005
                            • 16386
                            My industry remember, I build them for a living remember :)
                            William Pitt-
                            • joshh
                              • Aug 2004
                              • 6195
                              It's for your own good.
                              Nice placement by the way.
