Missing Flight MH370 777-200
  • Ether-D
    • Sep 2011
    • 2838
    #106
    It's been abducted by aliens.
    -Thread
    Originally posted by Andy.B
    I was born on 3/25…
    • DEV0 E30
      • Oct 2004
      • 8904
      #107
      -Thread
      • Farbin Kaiber
        Lil' Puppet
        • 29502
        #108
        • ThatOneEuroE30
          • Dec 2013
          • 8626
          #109
          Am I the only one that believes that? His theory makes perfect sense to me. The only thing that could cause it to be wrong is the plane only had 3000 miles of fuel.
          1991 318i 4dr slick top
          Mtech 2 turbo restoration
          • mulletman
            • May 2012
            • 801
            #110
            He's incorrect about how TCAS displays traffic with a transponder that's been selected to "standby" or "off." It will still show up on the display as one of those little diamond symbols, there just won't be an associated relative altitude number. A "primary target" only, is what ATC would call this. Depending on the TCAS system, this would issue a traffic alert to the airplane. I've gotten traffic alerts from airplanes that were 10,000 feet below me. You wouldn't get a Resolution Advisory as that requires operating Mode-S, but your screen defaulting to minimum range and turning yellow would get your attention.
            The other problem with this theory is that you'd have one hell of a time avoiding radar coverage once you broke out from behind the aircraft you're following. You'd have to pick some place rather remote, and as such you'd be up high in the flight levels, where radar contact is pretty much everywhere. Again, it's hard to explain a sudden VFR flight up close to 40,000 feet.
            If the airplane did indeed climb to FL450 like has been said, it burned a fair quantity of fuel doing it. In my airplane, fuel burn roughly doubles when compared to cruise flight if you're performing a climb close to the service ceiling of the airplane.
            I wish I knew where to find a winds aloft forecast for the time of the flight. That would help significantly with range in any given direction.
            • delatlanta1281
              Dart Master
              • Mar 2006
              • 10317
              #111
              Charles Whitmore
              Yours truly,
              Rich
              you kids get off my lawn.....
              • gkurey
                • 882
                #112
                It has been my experience that TCAS only works with powered transponders. You can absolutely turn it off and drop off the system for other users. I have trouble with helos all the time where I fly at because they don't squawk a lot of the time. Obviously approach can see em on the scope bu they can't tell you much else. Also have run into VFR traffic on a few occasions that didn't pop up on TCAS because they were'nt using a transponder. I thought that if you didn't have mode C then you get the diamond with no other info...like ships can create TCAS with no altitude info for example.
                • mulletman
                  • May 2012
                  • 801
                  #113
                  I think you're right. Obviously something like a Champ with no electrical system won't show up at all. However, the transponders on a transport-category jet are always powered, although they might not be set to report altitude. I know that in my airplane, my options are trans 1, trans 2, code, and ALT/STBY. Even on STBY, you'll still pop up. You'd have to completely power down the avionics system to kill everything.... and that just ain't going to happen.
                  Again, things might be different based on different equipment. I'm not sure what you fly, or how your TCAS might interpret data.
                  • Farbin Kaiber
                    Lil' Puppet
                    • 29502
                    #114
                    Originally posted by delatlanta1281
                    Charles Whitmore
                    Or Widmore for that matter.
                    • gkurey
                      • 882
                      #115
                      Very true...hadn't stopped to consider what selections there are for you guys as every plane I've flown, I have the ability to turn off the transponder alone, i.e. beyond a standby state. FWIW, I fly C-2s...our nav/comm/tcas is basically off the shelf civilian with a few exceptions to integrate it with older stuff we still use (military is my only aviation background besides a cessna here and there).
                      • Farbin Kaiber
                        Lil' Puppet
                        • 29502
                        #116
                        There is a nice, deserted, 445+km strip of highway in the middle of nowhere here, who needs a landing strip? With the proximity to The Stans, they could have landed, disembarked the passengers, and had a fuel truck or two on the highway to refuel. Not to mention who knows, maybe they jettisoned the cargo and passengers over the water... Fuct up thought, but...
                        We know how China is, maybe they got penetrated and don't want to admit how weak their powers actually are?
                        • mulletman
                          • May 2012
                          • 801
                          #117
                          If you land a jet that heavy on a highway, you'll shred the pavement, the tires, and probably end up collapsing at least part of the landing gear. Runway pavement is multiple feet thicker than highway pavement.
                          You'd probably get it down, but it's not going anywhere else once you do.
                          • M-technik-3
                            • 18946
                            #118
                            Depends on the weight. Most would break up but in some parts of the world Highways double as alternates for runways.
                            Used to see them in South Korea all the time. Gates close airplane lands, gates open traffic resumes.
                            Too many unknowns on this thing right now.
                            • Farbin Kaiber
                              Lil' Puppet
                              • 29502
                              #119
                              Now they are looking into the flight engineer that was onboard. The thing to me is, a lot of tail chasing is going on, and it seems like this is being handled like the US handled Katrina in the south, or the way Sandy went down up north. Screwed up, a week out, trying to figure out how to resolve the mess, and the mistakes made after the event too.
                              • Farbin Kaiber
                                Lil' Puppet
                                • 29502
                                #120
                                Since we are lucky to have some folks with wings under their belts, we can ask some questions... Opinions on this? (I think we might not have any triple guys here, but, I think we have some guys with experience on the bigger end of these things, so some input should be out there.)
                                What is the minimum length of runway a 777 would need for takeoff? presumably fairly well loaded with fuel to reach a distant target.
                                Ignore normal flap settings, accelerate stop distances, power settings, and any other safety margins.
                                Think about practicing these high flap radar power VMU takeoffs in your sim at home...
                                I bet you could do it in way less than 5,000 feet.
                                Just like it will land and stop in breathtakingly short distances. I bet a guy could get real good at doing VREF -10 landings if he had a sim at home...
                                Just sayin'
                                Also, on this land&takeoff theory, a 777 holds what, ~45,000gal of fuel? So, an 18 wheeler tanker holds about 6,000gal, so, they could pull a complete refuel, IF they had six tanker rigs on the desert highway, and, to likely not be seen, needed a rig to pump into that pumps all six trucks into the tanks at once, otherwise, they would be sitting on some ground for 6+ hours I'd guess. So, IF they had six tankers, a pump truck, and four tourist busses, the passengers could still be alive.
