Aero teaser
hey have you done a yarn test with video or pics? that would go a long way to showing the flow effect of what ever your calling those thingsbring it http://athomasmr23.mybrute.comComment
I think he owned himself by telling us that his aero testing is done by driving next to his car on the highway. Yarn and a couple of fixed mount cameras and I would be impressed but saying that just having one canard makes the car pull means absolutely dick. You could have your friend mooning out one window and if he (or she, this is a modern world) was fat enough you'd probably have the same effect...'89 325is S50 Track Montser
'04 X5 Daily/Tow Vehicle
http://www.avarestoration.com
http://www.myspace.com/brendanfiddle
Click here if you want to be my zombie slave...
http://www.youtube.com/user/Fidhle007
I don't think that the drag effect is totally useless just some more work needs to be done to show that it is having the intend effect
also get a manometer and take a pressure reading on the splitter and canard, that will show just how much front down force you are make PxA style i'm sure you know that thoughbring it http://athomasmr23.mybrute.comComment
ill get a yarn test and video to prove it in a bit... i got a ton of work between research and medical school.
This stuff is still about 90% black magic and 10% science.
Downforce is only useful in corners. For a fast track with lots of sweeping corners, downforce is obviously more important. For something like AutoX, not so much. The corners are generally too slow for small aero devices to help much (unless done in concert with other aero mods).
Under braking, yes, something like this could help. But it also makes braking more difficult to do consistently because as you slow, downforce goes away and you have to modulate more.
If these canards are helping at all, then I would suspect it is more that it is keeping more airflow out of the tire wells where it can stagnate and cause turbulence. A better mod would be vents over the top of the fenders. Again, it's all relative though. E30's don't make enough speed to be helped a lot by these smaller aero devices.
The splitter, and more importantly, the controlled airflow under the front of the car is going to be 99% more effective than just about anything else you can do on the front of the car. Of course, even that isn't much good unless the airflow is controlled as it exits from under the car.
It's you car. Have fun with it. What the heck right?1987 E30 325is
1999 E46 323i
RIP 1994 E32 740iL
oo=[][]=ooComment
reducing tire well and wheel turbulence is my interest in them I do a lot of long freeway hauls and i'm trying some things out for shits and giggle to try and reduce drag and increase down force at the same time. I like learn how things really work.bring it http://athomasmr23.mybrute.comComment
dive planesssssss ....
what do you think rear cover or venting in the rear skirt
