ABS Delete Any one runs without ABS
  • GK-E30M3
    • Apr 2008
    • 816
    my ABS is all screwd up sensors all mesed up diferent ABS rings up front should i delete the system or try to deal wit it
    Track Auto-x car
  • Erick
    Official R3V Drifter
    • 11169
    If it's a track car, you don't need ABS. Does nothing but kick in way too early.
    My ABS is completely disconnected.
    ..::Support FullOpp::..
    FullOpp Stickers for sale!
    Feedback Thread
    • BTP325ic
      • Apr 2009
      • 700
      fuck ABS delete that shit.
      • GK-E30M3
        • Apr 2008
        • 816
        do you know any good write up on ABS delete
          Remove power to the ABS controller and presto, no ABS. I've driven my Spec E30 with and without ABS. I can manage threshold braking either way and w/o ABS I can go a tiny bit deeper into a braking zone. But the downside of that is that is way too easy to flat spot a tire w/o ABS. So I fixed the ABS.
            • 34827
            it would also be good to have on a wet day
            • Wh33lhop
              • 11705
              Yeah, don't discount ABS, even the shitty ABS. If you're ever going to be running your car in the wet, keep that shit. Just pull the fuse when you're not using it.
              paint sucks
              • rThor432
                • Feb 2007
                • 3907
                It has it's pros and cons like most things. All I'm going to say in favor of it is that it saves tires. Other than that it's all bad.
                ^^My opinion. It doesnt apply for everyone.
                • Wh33lhop
                  • 11705
                  Plus, momentarily locking up the inside front on corner entry is cool. ;)
                  paint sucks
                  • Jean
                    • 18228
                    I don't miss ABS, I am not saying remove it if it's 100% working, but w/o it you'll learn to drive your car a little different and figure out in time just where the limit is w/o locking up your tires. Now for those times when you do need to make a panic stop, especially in wet, you'll probably be better off with abs unless you are very good with the brake pedal :)
                    • JGood
                      • Jan 2004
                      • 7959
                      I would never take the ABS off my track car. I'd rather lose the tenth of a second in the braking zone then a $200 tire. I don't know of any drivers I run with that are good enough to threshold brake perfectly every corner without lockup. I'm not racing for big $$$ so it's not worth it for me.
                      e30 restoration and V8 swap
                      24 Hours of Lemons e30 build
                      • kishg
                        • Sep 2006
                        • 2624
                        I'm with him..
                        '12 F30 328i Sport Line
                        '91 SpecE30 #523
                        '00 Ford F-350 Dually Tow Vehicle
                        BMWCCA #360858 NASA #
                        128290
                        • GK-E30M3
                          • Apr 2008
                          • 816
                          I guess i am keeping my abs
                          • Raxe
                            • 5346
                            My car never had ABS. :???:
                            • z31maniac
                              • 17566
                              Mine doesn't work, has never worked, so I'm just going to ditch it eventually.
                              www.gutenparts.com
