Light weight track battery
  • p0cket penguins
    • Jul 2008
    • 481
    #31
    Originally posted by 2002maniac
    On my 318is I had a 9lb Braille battery mounted up front with the rear cable removed. The stock battery cable weighs a ton.
    I am hesitant to move the battery from the rear to the front... I feel at the rear that it will help offset some of my weight in the drivers seat. Is it not possible just to run a smaller gauge wire to the trunk, maybe a 4 gauge?
    • !kid
      • 1362
      #32
      what about moving the battery more to the center of the car ?
      :borg:
      • Liam
        • 753
        #33
        It's really easy to get weight out of the back of these cars... So I don't see why you're sweating the battery unless you have really cut the weight out of the front of the car.
        Balance is important... Really important.
        But if you are absolutely insane about cutting weight and you get back to the battery and it's got to go as well, what we used to use were 2 motorcycle batteries in parallel (mounted in the front battery tray with an external boost lug)... Just enough to start a warm engine and smooth out the power from the alternator. But we're not talking 80's and early 90's DTM are we.
        Beyond all that Braille makes a fine product.
        I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃xS : φ(x)) → (∀xS : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".
        • Farbin Kaiber
          Lil' Puppet
          • 29502
          #34
          x howevermany for the Braille.
          • 1990m3
            • 1180
            #35
            I've been using a Deka ETX16L that I bought from Amazon for about $75. After extensive research I determined it was a good choice. Little sucker cranks my s50 over faster than the big ass battery that was in there before, and it always seems to have juice. A battery engineer told me to either disconnect it or use a battery tender if you don't use it for long periods of time and it can easily last 5 years.
            • RalleyTuned
              • 21
              #36
              we found a UPS truck back up battery that has juust enough cca to crank over our 13.5:1 race motor. I put one in my 16v rabbit and have only had a few chances to use it. held a charge great (bought it and installed it about a year later, and still fired the car right up), cranks fast, and is 13lbs. it cost about $40 shipped haha!
              it doesn't do so great with hot starts. it will fire but it is very nerve racking...haha!
              Ralleytuned.com Demonrally.com Traksclothing.com Spitfireefi.com
              • Feffman
                • Feb 2007
                • 338
                #37
                We use a Kinetick battery in our track car. Contact Barry at Performance Oil Store (www.PerformanceOilStore.com) for a Kinetick.
                Feff
                MVP Track Time :mrgreen:
                • p0cket penguins
                  • Jul 2008
                  • 481
                  #38
                  just installed the ext14 and it works like a charm
                  • FredK
                    • 14759
                    #39
                    O.O
                    I thought you were going to get the ETX18L!
                    But then again... you are addicted to losing weight like the thin Olsen twin....
                    • p0cket penguins
                      • Jul 2008
                      • 481
                      #40
                      yeah hahah... battery is 11.4 lbs and the new exhaust is 11 pounds even.
                      • whiltebeitel
                        • Apr 2007
                        • 2098
                        #41
                        Get on some scales, son!
                        '89 325i track sloot
                        '01 530i daily
                        -Enginerd
                        • p0cket penguins
                          • Jul 2008
                          • 481
                          #42
                          Ill be on a scale this sunday at NHMS
                          • xLibelle
                            • Aug 2004
                            • 2673
                            #43
                            duralast lawn and garden. 425CA
                            cheap and very light
                            • p0cket penguins
                              • Jul 2008
                              • 481
                              #44
                              Was on teh scale last week and weighted 2275 with half a tank.
