Bilstein Sport with Coilover question
  • Stephen
    Шлем ишака
    • 10774
    Well this thread proves it for me. My rear end bounces with 500# springs, and my shock mounts are fine, as well as poly sub frame and TA bushings. I guess i need to give bilstein a call.
    • z31maniac
      • 17566
      Your shocks may be blown. Bilsteins run with H&R Race springs at 570 in the rear. Or are you so low you are hitting the bump stops perhaps?
      www.gutenparts.com
      • Jean
        • 18228
        KONI / end thread.
        • Stephen
          Шлем ишака
          • 10774
          I think theyre blown. 500isnt too stiff, and im running the 6inn springs that used to be yours. so, low but not slammed. Hopefully billy will replace them
          • RalleyTuned
            • 21
            rebuild/re valve on bilsteins is only $75 each
            rebuild/valve on koni's is like $185ish each, not to mention they cost 2x as much as bilsteins and in my experiance with them on vw's in the past years, don't last nearly as long
            cant ever go wrong with bilsteins :D haha
            Ralleytuned.com Demonrally.com Traksclothing.com Spitfireefi.com
            • DRTSRFR
              • May 2008
              • 1836
              Keep in mind, the rear spring rate is totally different than the actual wheel rate.
              With a 500 lb spring the actual rear wheel rate is about 230.
              Suspension tips here...
              http://www.r3vlimited.com/board/album.php?albumid=757
              • E30_fiend
                • Apr 2006
                • 7348
                explain this
                • 884door
                  • Nov 2008
                  • 380
                  Originally posted by E30_fiend
                  explain this
                  The wheel is very far from the spring, and the trailing arm acts as a lever.
                  • E30_fiend
                    • Apr 2006
                    • 7348
                    I understand that. what I meant is where he got that number from
                    • JGood
                      • Jan 2004
                      • 7959
                      It's leverage. The rear suspension wheel ratio is .45, so 500 x .45 = 225
                      e30 restoration and V8 swap
                      24 Hours of Lemons e30 build
                      • z31maniac
                        • 17566
                        Good to know, I had been thinking the motion ratio was higher than that.
                        750 x .45 = 337.5 in the back
                        550 x .88 = 484 in the front
                        Interesting.
                        www.gutenparts.com
                        • DRTSRFR
                          • May 2008
                          • 1836
                          Thanks for doin' all the work for me!:)
                          • 2002maniac
                            • 4260
                            Originally posted by robmespeedy
                            any suggestions where i can get them done "cheap"?
                            Bilstein USA
                            • JRKOUPE
                              • Dec 2004
                              • 3159
                              wheel rate
                              why mention this......?
                              Was any1 discussing wheel rate?...or were you just expounding?
                              • DRTSRFR
                                • May 2008
                                • 1836
                                I was referring to the question in the original post.
                                What is the the maximum rate I can run on a bilstein before it needs to be revalved, or do I even need to worry about this?
                                ...and didn't see where anyone had considered it when discussing the rear of the car.
