anyone autox without powersteering?
  • richardkeith97
    • 1693
    wondering if you wish you kept it or if your happy without it? i just got my ps delete and not sure if i'm gona use it or not. originally when i got it i wasn't thinking about autox only dd. i got a little ps leak also and i'm hoping this will get rid of it depending on where its coming from. thanks for your input
    • 34844
    go ahead and try it and see. or just remove the belt for a couple runs.
    it might be okay on 195 or 205 street tires, but switch up to some sticky, wide r-comps on a tight course and I bet you'll want it back.
    • GSM07challenger
      • 671
      We run a 275/35/15 tire on a 15x10 wheel on our challenge car with out PS and it is not difficult at all to turn the wheel once you are moving.
      FS:///M-Tech Wallets.
      http://www.r3vlimited.com/board/showthread.php?t=224601
      • 2002maniac
        • 4260
        You've only got 9 fingers man. I'd keep it.
        • richardkeith97
          • 1693
          i've got stock tires on stock weaves. driving a car without a belt is much harder then driving a car without powersteering. i'm gona go ahead and do it. its easy enough to go back to ps if i don't like it
            • 34844
            yeah but it's probably stripped to the bone, right?
            although I suppose a lot of the ricers here are running gutted cars with no PS on the street, too. :p
            • gearheadE30
              • Jun 2007
              • 3734
              PS is definitely worth having on an autox course imho, unless your car is completely stripped. It is a lot easier to be precise with rapid steering inputs when you don't have to use as much force.
              Project M42 Turbo
              • lateracer
                • Sep 2009
                • 302
                I had my ps belt off for a while before I did the delete kit on my track car. Wanted to make sure I would be cool driving without it for enduro racing. Stock rims, Azeni RT615 tires. Did a few auto-x runs with both configurations. Steering with the delete kit made it a little easier than with just an unhooked pump, but it still takes a little umph for things like parallel parking...which isn't really done much enduro racing, but you get the point.
                While "driving in anger", I definitely prefer the feel of the steering now that the pump is gone. Even more than that, it clears up a lot of space in your engine bay and makes accessing things like fuel filter (depending on year), radiator master cylinders, etc. a lot easier. It's also one less thing that can go wrong.
                If my daily driver were to have PS issues, I would fix them instead of doing the delete on that though.
                • evil_twin
                  • Nov 2007
                  • 2965
                  I will agree with you here, but... If you actually found a nonpowersteering rack and throw that in, it feels the same :)
                  Paypal: vdang5@gmail.com
                  Delta Auto Care
                  2875-C Towerview Road
                  Herndon, VA
                  703.435.1375
                  My Feedback Thread: Evil_Twin
                  • Lurker27
                    • 821
                    Non-powered E36 rack is the setup of kings.
                    '89 335is +turbo
                    • guibo09
                      • Dec 2008
                      • 834
                      i think powered short ratio is best for auto-x unless you have a terribly light front axle (like on an elise).
                      90 E30 325i
                      • evil_twin
                        • Nov 2007
                        • 2965
                        /close thread :-P
                        Delta Auto Care
                        Herndon, VA
                        703.435.1375
                        • Jonny Cash
                          • 1763
                          ricers.. your funny. Some people daily drive w/ no PS, and love it. I removed the belt on my 318is when the pump went, and it wasnt hard to drive at all. I enjoyed it. I was hesitant to remove it on my current 325 because of the little extra weight up front, but now with more input on properly deleting the pump- Im taking it out.
                          -Jay
                          2014 NASA FL se30 champ #81
                          2001 se46 3 year plan in progress
                            • 34844
                            yeah, ricers. What's the purpose of a stripped out street car? beating civics light to light?
                            • Jaxx_
                              • Dec 2009
                              • 1880
                              better fuel economy? :P
