Alternative to Wilwood BP-20 pads
  • gverelli
    • Dec 2008
    • 772
    #31
    I was looking on wilwoods site at the temperature curves and torque values, what about the J compound? it looks pretty good and WAY better than bp-20 curves.
    Actually, I dont think the J compound is available for this caliper..
    G.Verelli
    • gverelli
      • Dec 2008
      • 772
      #32
      Lee, what Wilwood compound would be equivalent to the HT10's? For example having HT10's in the rear and H compounds in the front?
      G.Verelli
      • JRKOUPE
        • Dec 2004
        • 3159
        #33
        r u running an m20?....if you are, you are overthinking the rears IMO. Use HT 10 up frt....and any hi po rears....HP plus...Mintex (1144) I think..... carbo tech...etc.....
        • gverelli
          • Dec 2008
          • 772
          #34
          Ya I have an m20. My current pads are BP-20's up front, and Hps rear. I am looking for a setup with much more bite. Pretty much in the same situation as the OP. I would like to stay with Wilwood pads for the front kit..
          G.Verelli
          • SkinnyVT
            • Nov 2008
            • 391
            #35
            I run the H compound in the front and HP+'s in the rear, the balance of the car was very neutral under braking. This is with all the tar out of the trunk so the car had a 3.5% front weight bias.
            '86.5 325eis Track Ho | '08 128i DD | '04 Silverado Tow Vehicle
            • kishg
              • Sep 2006
              • 2624
              #36
              stock m20, go ht-10s all around or better pfc06 all around. if you want to dial in a little bit more rear bias, use pfc01 rear with pfc06 fronts.
              '12 F30 328i Sport Line
              '91 SpecE30 #523
              '00 Ford F-350 Dually Tow Vehicle
              BMWCCA #360858 NASA #
              128290
              • gverelli
                • Dec 2008
                • 772
                #37
                Are your refering to having all stock size brakes? Or, with the Massive street kit?
                G.Verelli
                • JRKOUPE
                  • Dec 2004
                  • 3159
                  #38
                  w/ more rear bias, car will rotate a bit easier?.....
                  did you notice that?...
                  stock m20?....hehehe...sure.
                  • gverelli
                    • Dec 2008
                    • 772
                    #39
                    I was thinking of putting the H comps up front and the HT10's in the rear, I just want to know if this will be okay for track use. Ill be honest, right now it feels as if the rear are doing nothing. Both are rebuilt functioning 100% with HPS on them.
                    G.Verelli
                    • kishg
                      • Sep 2006
                      • 2624
                      #40
                      should have clarified, i meant with stock brakes, stock m20.
                      '91 SpecE30 #523
                      128290
                      • kishg
                        • Sep 2006
                        • 2624
                        #41
                        yes it does rotate easier. not sure it makes a huge difference in an HPDE. hey, you accusing me of cheatin mister? :)
                        '91 SpecE30 #523
                        128290
                        • Massive Lee
                          • Sep 2006
                          • 6782
                          #42
                          A car that is more stiffly suspended will experience less weight transfer. Therefore as a general rule, it can take more rear bias than a stock car. The weight of the engine will have incidence on the pressure the front wheel will apply on the asphalt, and will affect the required bias for optimal braking. Also, tight tracks will require more rear bias to allow the back end to help steering. Fast tracks with long sweepers require less rear brake.
                          massivebrakes.com
                          • JRKOUPE
                            • Dec 2004
                            • 3159
                            #43
                            I dont know.......are you saying HPDEs is not racing?.........lol
                            • kishg
                              • Sep 2006
                              • 2624
                              #44
                              naw, that's practice :)
                              '91 SpecE30 #523
                              128290
                              • gverelli
                                • Dec 2008
                                • 772
                                #45
                                Also, I would still keep my bp-20s for street driving, but will the rotors be okay to be swapping back and forth H compounds then bp-20s before and after track days?
                                G.Verelli
