Alternative to Wilwood BP-20 pads
    Okay bad news. The f'in pads don't fit. They're far too thick and the local machine shop couldn't take of 3mm from each pad simply because they didn't have the cutting tools.
    Does anyone know what I can do in this situation besides telling Porterfield these are no good?
      Anyone?
        You run Dynapro calipers. Right?
        What type of duty you expect? Track? if so, I suggest Wilwood's H compound for the track, and keep the BP20s for the street. H pads have a very high coefficent of friction. I don't know one person who disliked it for track duty. That pad is not harsh on rotors as long as it is not daily driven. It is also (relatively) long lasting. And as it is a pad made for Wilwood by Raybestos, you can be sure it will fit the caliper. The pads you got from Porterfield are most likely 16mm thick, while you need the 12mm units.
        Hope that helps. ;-)
        Lee
        massivebrakes.com
          You could try a different machine shop. I've used a high speed steel fly cutter on a manual mill to face race pads. This is very basic equipment that any machine shop should have.
          Hopefully more companies will start to support the dynapro caliper soon.
            Lee
            Lee, I bought the HT-10's specifically for track use. I don't want to return these because porterfield will charge me a restocking fee, I would much rather find a machine shop that has the proper tools to mill the brake pad.
            I'll definitely give the wilwood compound a shot after I use these pads up...will make things much easier since they make a pad for the caliper. As long as they're 12mm I'll be happy :)
            Do you want to do mine? I'd be more than happy to ship these to ya and pay for the service...Let me know if you have the time.
              HT10s are very good pads. Very forgiving and working and progressive in the rain too. Just remove a thin 3mm layer and you should be golden. If you have an hour to kill, simply rub them on coarse asphalt in an "8" shape to distribute the wear. It works great. I did it two years ago with 21mm pads doing down to 16mm, at a race weekend. But it takes quite some time.
              massivebrakes.com
                bring em to guten tonight, we'll pass them around for everyone to give a "rub" :)
                '12 F30 328i Sport Line
                '91 SpecE30 #523
                '00 Ford F-350 Dually Tow Vehicle
                BMWCCA #360858 NASA #
                128290
                  Indeed, thats why I chose em. Several track guys recommended them, along with yourself.
                  That's a good method albeit an incredibly long one. We'll see if 2002maniac can help me out or another local machine shop before I attempt to manually shave it down on asphalt!
                    I'm not sure I'll want em back!! LOL
                    I won't be able to make it this evening...it's my womans birthday tonight.
                      bring her! what's better than a guten party? :)
                      '91 SpecE30 #523
                      128290
                        i would man...she already made plans with her friends. too complicated.
                        L should have made it friday :(
                          There is lots of good info here. Thanks for the link, Dude!
                          S50'd
                          Originally posted by TDE30
                          What is this faggy shit I have happened upon?
                          I can always live in a M3. Can't M3 a house.
                            No probs man. I'm going to be installing these pads very soon.
                              Dude, do you have any idea what the problem is that caused you to receive the 16mm thick pads? Doesn't 7812 indicate a 12mm thickness?
                              S50'd
                                To be honest, I don't think that Hawk makes a 12mm pad...The next set of pads will likely be Wilwoods that fit.
                                Wilwood’s complete line of brake pads includes Smart Pads, PolyMatrix and specialty pads. Brake Pads
