Questions for E30 drifters
  • Highway1
    • Jan 2009
    • 773
    #166
    Originally posted by Erick
    Yeah, but e30s don't need that as they can be set to lock or not lock from factory :)
    wait... what?
    • accident
      • 7303
      #167
      Originally posted by Highway1
      wait... what?
      unscrew the thumb button, remove spring, screw thumb button back on.
      Moral of this story?
      • e30trooper
        • 11576
        #168
        Originally posted by PedoBearE30
        found this thread most usefull
        clean s13, think ive seen you around on zilvia. glws
        • Erick
          Official R3V Drifter
          • 11169
          #169
          ^ What he said
          ..::Support FullOpp::..
          FullOpp Stickers for sale!
          Feedback Thread
          • agustingig
            • Dec 2009
            • 140
            #170
            Im running a m50nv with lowtec stiff dampers, i have cut m3springs in the front and some pos lowtec springs in the rear, springs are next on the list, im runing a welded 3.91 diff gives me like 85kmh in second gear, rarely have to use 3rd gear on the track we have here in iceland... Stiffer springs are deffinitely on the list, and a widermtrack in the front,, overall pretty good learners setup, although it deff needs less bodyroll :D
            Cheers
            • Alexander.
              • 32
              #171
              perfect e30 drift car shopping list:
              1x e30
              1x 1jz
              1x microtec
              1x w58 gearbox
              1x hsd front weld on sleeves for the front(like gc)
              1x r32 front coilovers with custom made top bushings.
              1x 2 months long nights and unforgetable memories!
              1x alot of dramas and headache!
              this is what we did when i sold my e30 1jz package to a mate(im going m30b35)
              we made 400.6rwhp it went like all hell and skidded like a boss brakes didnt exist and steering was shit. best time of our lifes!
              please note 10kg front springs and 8kilo rear there was no fuel tank or spare wheel well. it was fully stripped out with re wired car!
              • PedoBearE30
                • Dec 2010
                • 44
                #172
                thank you !! and yeah you prob have seen me on zilvia
                sigpic:hitler:
                • e30trooper
                  • 11576
                  #173
                  I was on there ages ago. Joined back in 03 , but havnt had a s13 since 07. was never a post whore on there.
                  great car for my 1st car , used to show up to the meets a boba loca in Torrance and long beach but in a e30 lol
                  i miss it so much. cant think what would have been done it now. ( was hit car was done with )
                  • Chaos Theory
                    • 185
                    #174
                    Same philosophy as the aluminium "drift buttons", they're just "cool" because they're anodized.
                    • accident
                      • 7303
                      #175
                      in theory it's also easier to lock it as well since they have the lip on them.
                      • Highway1
                        • Jan 2009
                        • 773
                        #176
                        Thanks man
                        Here is my setup
                        M42 with chip and ford injectors
                        Welded 4.10 diff
                        IE springs
                        Billy sports
                        IE Big Sways
                        IE Poly subframe and trailing arm bushings
                        M3 control arm bushings
                        e36 steering rack
                        my alignment:
                        Front: 0 toe 1.6 camber
                        Rear: 0 toe 1.2 camber
                        I need more power but for now it works. I want to add spacers on the tie rods for more angle but my rims (17x7.5 et20) are hitting the sway-bar at full lock so i need some spacers first. also something needs to be done about my crappy ebrake. Adjustment? new shoes? hydraulic? something...
                        • JakeP
                          • 315
                          #177
                          New shoes and adjustment should make a world of difference. Make sure the tension is equal side to side. A hydro brake (cutting brake) also does great. Drift hard and long enough using that ebrake and the handle will break though. ask me how I know. :p
                          • Ian Bowers
                            • Apr 2008
                            • 1120
                            #178
                            Thanks man
                            Here is my setup
                            Welded 4.10 diff
                            IE springs
                            Billy sports
                            IE Big Sways
                            e36 steering rack
                            my alignment:
                            New shoes should work, I have 0 problem locking mine up at the skidpad. I'm solving the power issue with a little Eaton, hopefully. :)
                            • gnarlycreature
                              • Apr 2007
                              • 233
                              #179
                              Originally posted by KennyT
                              Contact patch width does not equal rim width, unless you live in stretch land. Also, higher end tires tend to recess at the bead allowing you to run wider tires on a narrower wheel. My Khumo 711's are this way, as are the Bridgestone RE-11's in my basement.
                              M Roadsters came with 7.5" wide fronts with 225s, 8.5" rears with 245s.
                              Stop doing coke.
                              Rears are 9s sir.
                              • KennyT
                                • 542
                                #180
                                Originally posted by gnarlycreature
                                Rears are 9s sir.
                                Fronts must be 8's then. Did wheels change other than finish in the s52 to s54 Roadsters?
