Questions for E30 drifters
  • BimmerScreamer
    • Dec 2008
    • 413
    #121
    i think the biggest limiter is usually the driver not just the setup, try letting someone better then you drive your car and you'll see. The best mod is the driver.
    (not aimed at anyone just my .02)
    Anything can be done
    • MaxBell
      • 1391
      #122
      This is true in all forms of racing. I started drifting a VW Beetle in the Ottawa snow. Got an E30 and did a bunch of relearning to get used to the car. I know we all want to look for some wondersetup that is super easy to drift. There is none.
      As for me, I have added and changed parts as I go along. I first upgraded the brakes to some 3DG slotted rotors and Red Stuff pads. I also upgraded the sway bars to thicker Eibachs.
      Drift drift drift... then I changed the springs to H&R and shocks to Bilstein Heavy Dutys.
      Drift drift drift, I changed the steering wheel to something smaller. Added an M30 intake and chipped the engine.
      Drift drift drift, upgraded the injectors to 19lbs. and added a cherry bomb muffler and custom catback exhaust. Swapped to some harder springs.
      Now I'm in the drift drift drift stage again, just getting back on H&R springs (they kick ass). Now, if I had jumped into the car I have now as a novice, I wouldn't have an understanding of the limits of the car and how they change and react. I know the car super well, even to the point where I have no problem noticing what I'd change in other E30s to make it like mine.
      I hate to be a dick, but that's about as definitive an answer I can possibly give.
      REMEMBER: Be safe and have fun is Rule Number 1.
      The Epic Unbuild of Clint Eastwood
      • shiboujin
        • Feb 2006
        • 2791
        #123
        You guys make it seem like any RWD platform can drift like FD. I'm researching to find the forumula for the best E30 drift car. Can you drift a stock car? yes. Can you drift a stock car well? Kinda. Can you drift a mildly modded E30 at an FD level? no.
        As I've progressed, I've learned a few things that would have made me a better driver sooner. IE stumbling around modding my car made my car harder to drift and not better.
        IE my general short list for E30 drifters is this:
        side wall flex contributes to large amounts of body roll. 15" minimum for rims
        sway bars are your last method of controlling body roll. Springs are prior to that.
        When you get really stiff, no rear sway bar is preferred
        Now if I had known these few things from the beginning, I wouldn't have fucked with stock bottle caps for so long.
        Also, HR Race springs are soft as hell. Most competitive E30s run spring rates near 1000#. Jstock is ~900 front and 1100 rear. HR race is 300/500.
        • Chaos Theory
          • 185
          #124
          Have to agree except for Formula Drift, that is probably the most boring "drift" to watch. Just extended power slides on long sweepers.
          The drift basics are the same for all cars.
          • FR Manual, lock the rear - Welded will do fine but an LSD is preferable.
          • Eliminate body roll - Coil overs with stiff spring rates(in an E30 probably 10KG/MM front and 12KG/MM rear). Fat sway bars, adjustable is unnecessary.
          • Reduce sidewall flex - No over sized tyres(245s on 8s etc) but you will want good tyres that grip well. Stretch is not really recommended.
          • Increase lock - Modify steering knuckles/change rack/tie rods etc
          Power is unnecessary. If it bogs down, kick the clutch.
          Have fun.
          • Mike The Bavarian
            • 488
            #125
            Have fun.
            245 on a 8 is proper sized you bozo....
            • Chaos Theory
              • 185
              #126
              How? 245 is almost 10 inches wide.
              10" > 8".
              • Mike The Bavarian
                • 488
                #127
                10" > 8".
                225-245 is perfect on a 8"
                • Chaos Theory
                  • 185
                  #128
                  • KennyT
                    • 542
                    #129
                    Contact patch width does not equal rim width, unless you live in stretch land. Also, higher end tires tend to recess at the bead allowing you to run wider tires on a narrower wheel. My Khumo 711's are this way, as are the Bridgestone RE-11's in my basement.
                    M Roadsters came with 7.5" wide fronts with 225s, 8.5" rears with 245s.
                    Stop doing coke.
                    • shiboujin
                      • Feb 2006
                      • 2791
                      #130
                      I run 245s on my 9" wide
                      • Mike The Bavarian
                        • 488
                        #131
                        notice that I said 225-245...some tires run small and vise versa
                        • Jaxx_
                          • Dec 2009
                          • 1880
                          #132
                          I'm gonna agree with mike on this one. I ran a 235 on a 7" and that was OEM fitment. I later changed to 215 for the application, but i wouldn't consider 245 "oversized" for a 8".
                          • direction88
                            • Feb 2007
                            • 228
                            #133
                            E30 for drifting. I'm guessing you were the kid who's parents made him do figure skating rather than play hockey... Tough brake.
                            "Drifting an E30 is like pouring out a beer just to get a nickel for the can"
                            • Danny
                              • 14216
                              #134
                              And you must have been the one who was home schooled.
                              • lolcantturn
                                • 4588
                                #135
                                you must be homosex.
                                Originally posted by TSI
                                OEM+
