Scca class help
  • BMW_TUNER
    • Jul 2006
    • 1386
    Scca class help
    I am trying to figure out what class I will be running in if I choose to compete this upcoming year. I am factory chassis s50 with software g260. E36m3 5 lug, factory dif and ds. 95m3 steering, deleted back seat. Autopower roll bar, gc coil overs, gc race camber caster plates. Adjustable rear subframe all remaining bushings poly, treehouse eyballs. Twin custom exhaust with cat . Mason strut tie bar. Carbon hood. No ac no abs no bs. Staggered e36 m3 17 ltw's with 245/35/17 rear 235/40/17 front. 2700 lbs without my fat ass.
    Any help is appreciated.
    1989 332IS -S-Fiddy Four-Some weight removed.
    5 lug E36 M3 Brakes Coilovers and LTW's and No ABS.
  • NigelStu
    • 827
    Road Racing or Autocross?
    I'm going to assume Autocross, since you mentioned a roll bar and not a roll cage.
    With those mods, I'd say one of the Street Touring classes. STX maybe?
    Get familiar with the rules. You may need to backdate some parts if you want to be competitive (to get into a lower class). There will be somewhere you can run the car as is, so get out and do it!
    Rules can be downloaded here:
    http://www.scca.org/contentpage.aspx?content=61
    Ben
    Thelma-Louise, the '88is Chump Car - back to M20 power!
    2014 ChumpCar Season Schedule!
    April 5-6 Autobahn, IL - Sat: 1st! Sun: 3rd
    May23-25 Watkins Glen, NY: 4th, 5th, 4th
    October 4 PittRace Sprints: 2nd in C-class
    October 18-19 NCM, Bowling Green KY: 2nd, 1st!
    Nov 1-2 Watkins Glen - Chumpionship - 1st car to exit the race with significant body damage :(
    Find us on FB! Schaut Speed Motorsports
    • e30fish
      • Oct 2009
      • 332
      all the way up to SMod
      • BMW_TUNER
        • Jul 2006
        • 1386
        Thanks. Sorry I forgot to mention auto-x. I have run novice a few times but I would love to compete. I was thinking I would be S-mod after reading the rules that sucks for me because there are some crazy cars in S-mod.
        • //MPower
          • Jun 2007
          • 182
          I'm pretty sure that would put you in E Modified. SCCA rules aren't ideal for engine swapped cars short of full blown race cars.
          Street Mod doesn't allow engine block swaps.
          16. STREET MODIFIED CATEGORY
          16.1 ALLOWED MODIFICATIONS
          D. Drivetrain and related components (induction, ignition, fuel systems,
          etc.) are unrestricted except for the following limitations:
          1. Engine block must be a production unit manufactured and badged the same as the original standard or optional engine for that model.
          MODIFIED CATEGORY
          MODIFIED CLASS E (EM)
          Modified Production and GT cars as follows:
          A. Weight (with driver) vs. Displacement
          Piston engines up to & including 3200 cc OHC: 1700 lbs
          Piston engines up to & including 4500 cc pushrod/OHV: 1700 lbs
          2-rotor rotary engines w/ unrestricted porting: 1700 lbs
          Piston engines unlimited displacement: 1800 lbs
          3-rotor rotary engines w/ unrestricted porting: 1 800 lbs
          B. Performance Adjustments
          AWD: Add 300 lbs
          Modified Tub: Add 50 lbs
          C. Weight Bias Adjustment - with driver sitting in the driver’s seat
          RWD w/ less than 51% weight on drive wheels: Deduct 50 lb
          FWD: Deduct 50 lb
          | Jimmy | 1999 M3 | 1986 325 ES |
          • Danny
            • 14216
            You might even be up in XP.
            • BMW_TUNER
              • Jul 2006
              • 1386
              I am hosed. I guess I will just run for fun.
              • BMW_TUNER
                • Jul 2006
                • 1386
                I just looked into it and I have a shot at winning xp due to the reliability of my car. The Other XP competitors have trouble making it into every event.
                • Jalves619
                  • 596
                  Nice I was about to ask almost the exact same question. My setup is pretty similar to yours but I haven't decided whether or not to weld in rear camber/toe adjusters. From what I've read thats the only thing that would bump me out of SM into $M.
                  • 7pilot
                    • 475
                    Cherry picker.
                    m
                    • BMW_TUNER
                      • Jul 2006
                      • 1386
                      I just talked to the regional man in charge and he informed me that I can Run SM with all the boosted subbies. That should be fun.
                      • e1_griego
                        • Jul 2009
                        • 73
                        There's no rollbars in SM. Pretty sure the bar throws in a prepared class.
                        • //MPower
                          • Jun 2007
                          • 182
                          So he is making a personal exception?
                            • 34844
                            that says you can't swap engines from other makes. S52 swaps are okay, LS1 swaps are not.
                            • BMW_TUNER
                              • Jul 2006
                              • 1386
                              According to the director at large
                              "SM allows any motor from the same manufacturer or Family of manufacturers for cross branded cars"
