anyone just running baskets? will any r compounds fit on them?
what wheels and tires are you guys using at the track?
Tags: None
trent
Re: what wheels and tires are you guys using at the track?
THE PIMP ONES f00!!!!Originally posted by nickmp0weranyone just running baskets? will any r compounds fit on them? -
yes. they're pretty nice wheel. wide enough, and light enough. cheap enough definately.Originally posted by nickmp0weranyone just running baskets? will any r compounds fit on them?
yes. people can buy 225/??-14 R compounds and one of the club racers Jet H. was using them IIRC.
but be careful, they are S-O-F-T and will bend easily. That's why I have more bent weaves than I could care for. But cheap enough and easy enough to replace. Having wheels easily available is good.
That's the only thing weird about my Panasports (the wheels Trent used to use as track wheels). Supposedly Kyle (bimmer8604)'s boss has a bunch and can get them, but they're rare and about $200 a pop, so replacement might not be easy.Comment
also smaller diameter = cheaper tires.
trent has 17in superleggeras too and the tires cost more to replace then 15" ones. another consideration.
MOST IMPORTANTLY THOUGH. why do you need R compounds?
Have you ever even been on the track? Didn't you ball up your former 318is on the street?? You probably don't need to be fucking with Rs yet.Comment
Just get you some Falken Azenis. You can drive them on the street if you want and they have great grip for the track. They are also about as cheap as anything you can find.
"Modern cars may be able to outgun it, but few can match its character, its motorsport spirit, and the way it plasters a huge grin on your face at any speed." - Patrick George
1988 M3 - Track Rat
1989 325iC M50 Vert
1989 325i Coupe
1991 318is
1995 318ti Club Sport
2006 330i e90
2008 Tundra CrewmaxComment
well, i think im going to be getting the goodyear eagle f1 gsd3s and they are known to be a GREAT tire but i have heard of people having problems wit them chunking and ruining them in a matter of minutes. SO i want to get some wheels and tires for the track and thought why not go with something that will have a lot of stick. Im used to racing tires on my kart anyways. although the time the r compounds will last is kind of a turn offComment
novices shouldn't use r compounds. and usually won't be allowed to.
"why not go with something with real stick" i.e. more stick than you need or is safe.
my azenis lasted two weekends, including a few sessions of SERIOUS abuse. they get a little greasy, but do great and can handle it.Comment
and that is because you suck at life
http://www.tirerack.com/tires/tires....es&place=0
http://www.tirerack.com/tires/tires....es&place=5
$180 and $140 each.Comment
