guys who run separate tires at the track..
  • JGood
    • Jan 2004
    • 7959
    I put 4 205/55/14's, all my spare parts, a jack, etc.. in the trunk.
    Go a little wider, and you can get three in the trunk and put the other one inside. I have a roll bar inside so it actually becomes difficult to get a tire inside the car.
    e30 restoration and V8 swap
    24 Hours of Lemons e30 build
    • 1991 e30 bmw 318is
      • 523
      use to put in back seat/one in trunk with jack and stuff... but put a roll bar in over the winter. so I made up a rook rack for them...
      only pic i have its not exactly done in this pic but you get the idea...
      91 e30 318is M50 SOLD
      http://www.r3vlimited.com/board/showthread.php?t=149570
      92 325 vert project
      http://www.r3vlimited.com/board/showthread.php?t=341370
      • PaintPro21
        • 660
        My friend with his tracked out E36 M3 would take his 4 wheels/tires on a roof rack. Should be no problem on an e30 either.
        ApexRaceParts.com - Facebook - Twitter
        • gearheadE30
          • Jun 2007
          • 3734
          I've had 2 sets of wheels in my coupe before, with one wheel in the spare well. I usually just put the track tires in the back seat though. I like that tire tail thing...
          Project M42 Turbo
          • Boris3
            • Apr 2007
            • 444
            I must suck at packing. I can only fit two of my 205/55/14s in the trunk. With the roll bar the other two have to go in the passenger seat. Do you get more clearance in the trunk without the tar to be able to stack the tires, or are the dimensions slightly different in the late versus early model e30s?
            1990 325: track/racecar
            2003 330xi; project car
            2004 330i zhp: civilized car
            • JGood
              • Jan 2004
              • 7959
              I have everything removed from the trunk. Any trim, carpet, tar, etc... is gone. You need every last millimeter to be able to stack them three high (one in the spare tire hole, two on the trunk floor, one on top of them). Actually, I can do it with weaves, but it probably wouldn't work with a 7" wheel. I can't even get close with my 205/50/16's on an 8" wheel, I know that.
              • Boris3
                • Apr 2007
                • 444
                One more reason to clean out the trunk. Thanks!
                • M-technik-3
                  • 18946
                  Simple utility trailer.
                    • 34844
                    4 doors FTW
