s50 in an e30 - track application
  • FredK
    • 14762
    I don't use rope or compressed air. I just bring each cylinder pair so that one is at TDC. At that point the valve has a maximum of a few millimeters to fall.
    It used to be a cheap job, when you could get a set of 24 spring plates and 48 split collet retainers for around $110.
    Now the same parts are around $300, IIRC.
    • Wh33lhop
      • 11705
      Originally posted by nrubenstein
      Recently, the general consensus in the racing community has been that the official date may not be correct. Pretty much, if they haven't been changed and you care about the motor, you should change them.
      I stand (gently) corrected.
      paint sucks
      • ethirdy
        • Nov 2007
        • 406
        Is that OEM parts?
        Originally posted by alpinaclone
        Since the real economy is in the shitter, I say we start our own.
        This is how it works; you buy my junk, then I will buy more junk and so on so forth etc. etc. Think of the future of your children and buy my stuff.
        • ForcedFirebird
          • Feb 2007
          • 8300
          But then don't you have to compress the spring that much more to get the locks in?
          john@m20guru.com
          Links:
          • JRKOUPE
            • Dec 2004
            • 3159
            Originally posted by Vivek
            Most people will tell you not to play the "while you're in there" game. Just make sure the engine's well sorted and inspect anything else that is broken/may soon break (steering rack, etc) that is easier to access with the engine out.
            who do you hang with?......not car guys fo sho.
            steering rack??????......
            "while you are in there" is a smart game to play.
            • hwy84
              • Aug 2009
              • 190
              Most people will tell you not to play the "while you're in there" game...
              That's funny.
              Since you have the pan off, baffle the e34 pan, safety wire the oil pump nut, and change the rod bearings. If the motor has seen low oil pressure ever, the rod bearings will have gone dry, and will be worn. Super duper easy and fun to do, and great piece of mind on track. The bolts are TTY, so get new ones.
              Don't use a victor reinz gasket anywhere.
              Retainers are a good thing, unless you want to drop a valve so you have an excuse to build up an s52 later. :)
              Current:
              1991 325i Sedan - S50 Swap
              1988 325i Cabrio
              Past:
              1991 M3
              1991 318is
              1985 325e
              • VinniE30
                • 2113
                Does the m50 have the same valve retainers as the s50? So any 24v before 10/95 would have the bad retainers then?
                Zinno '89 <24v swap in progress>
                • DrewSkii
                  • Jun 2011
                  • 449
                  • e30shmobberr
                    • 1934
                    Originally posted by nando
                    +3
                    Patrick - IG:niicknac
                    RIP 1987 BMW 325is - S50'd ZF 6-speed, flared, bagged
