s50 in an e30 - track application
  • jstam
    • Jul 2010
    • 48
    I'm gearing up for an engine swap in the e30 - if I'm dropping an s50 in, what else should I be doing to the motor while it's out and I have access?
    I'm looking for some guidance on modest improvements that will address the reliability, durability etc. for what will be some DD but mostly track use. I'm not looking for huge HP gains (or maybe none). I'm not building the car for a specific class - just reliable HP is what I'm looking for.
    I imagine things like baffled oil pan, etc. are key. What else?
    1985 325e, 74k miles (S52 w/ OBD1, Bistein Sports, H&R Sports, IE sways, 3.23 LSD, TD 15x7/Star Specs, Euro bumper conversion)
    1998 M3 (4dr, 5sp, TCKline) (sold)
    2002 325i (sold)
    2009 X5 3.0si
  • gp.plus
    • 416
    Make sure you use a sealant like rtv along with the oil pan gasket when you swap pans, don't just rely on the gasket, especially if it's victor reinz. Just clean the motor up real good and maybe put new orings on the injectors. If the rear main seal is not leaking don't mess with it, if you do get the new style that has the white plastic insert to help with installation.
    • nrubenstein
      • 3148
      On an S50, change the valve retainers if you're serious about track use. Most S50s were built with weak retainers that are prone to failing, resulting in a dropped valve and a trashed engine.
      2002 BMW M3 Alpinweiß/Black
      1999 323i GTS2 Alpinweiß
      1995 M3 Dakargelb/Black
      - S50B32/S6S420G/3.91
      1990 325is Brilliantrot/Tan
      1989 M3 Alpinweiß/Black
      • markseven
        • Sep 2006
        • 5327
        Metal or composite impellar'd water pump.
        Tack weld or safety wire the oil pump nut.
        IIRC, the metal thermo housing, too.
        Urethane motor and trans mounts
        Pusher fan fo sho. Under threshold braking the engine will move a lil.
        I Timothy 2:1-2
        • alisjack770
          • May 2012
          • 1
          hi
          welcome to this forum site ....
          Animation Tutorial
          • Charlie
            kid tested, administrator approved
            • 6686
            Originally posted by Vivek
            Most people will tell you not to play the "while you're in there" game. Just make sure the engine's well sorted and inspect anything else that is broken/may soon break (steering rack, etc) that is easier to access with the engine out.
            Who's gonna tell you that?
            If the engine is out of the car, do everything. All the seals, fluids, little hoses, plastic intake shit, etc. Hell of a lot easier to do these things while it's on a stand vs stuck in the car.
            He's gonna be swapping the oil pan anyway, so definetly go with a baffled part, do the water pump, do all the rear little hoses, get the main seal, etc.
            -Charlie
            Swing wild, brake later, don't apologize.
            '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
            FYYFF
              • 34844
              • nrubenstein
                • 3148
                -Charlie
                If the main seal isn't leaking, don't touch it. If it is, well, it'll probably still leak after you change it, but it will probably be better.
                • E30Pedia
                  • 140
                  double check the VTEC before installing.
                  Or even better, triple check it.
                  Useless post was useless. :|
                  • ForcedFirebird
                    • Feb 2007
                    • 8300
                    lol.
                    Yeah, there are tricks to get them to seal, even though there's a grove worn in the metals, but it's tough dealing with parts that have miles on them.
                    john@m20guru.com
                    Links:
                    • Wh33lhop
                      • 11705
                      If you have a 9/95 S50 or before they have the old retainers. 10/95 and above have the good ones already.
                      Unfortunately it is not a particularly trivial job to do in any sense, either. :(
                      paint sucks
                      • ForcedFirebird
                        • Feb 2007
                        • 8300
                        It's a pain, but can be done without pulling the head. I have stuffed rope in the spark plug holes, then rotated the engine to hold the valves up, then you can work from the top. When done, rotate the engine back a bit and pull the rope out.
                        john@m20guru.com
                        Links:
                        • nrubenstein
                          • 3148
                          Recently, the general consensus in the racing community has been that the official date may not be correct. Pretty much, if they haven't been changed and you care about the motor, you should change them.
                          Also, instead of a rope, you can pressurize the cylinders with air to keep the valves closed.
                          • ForcedFirebird
                            • Feb 2007
                            • 8300
                            That works too, but prefer the rope in case you need to hold one for a length of time. Would suck to lose pressure for whatever reason and watch the valve fall into the chamber.
                            john@m20guru.com
                            Links:
                            • robgoesvroom
                              • 821
                              Originally posted by nando
