Drift Car Dreams?
  • camip
    • Nov 2011
    • 1253
    Don't even have it yet the neighbor has a e23 733i and I swear i read somewhere that they came with a medium case 3.46lsd just need to check and it's mine. Looks like I'll just set up the eta for weekend drift duty.
    • Dj Buttchug
      • Jun 2010
      • 7688
      fwiw 346 ratio is kinda rare. if it indeed has one you are a lucky bastard. Ive been trying to source one for a longggg time
      Turbo M42 Build Thread :Here
      Ig:ryno_pzk
      I like the tuna here.
      Originally posted by lambo
      • camip
        • Nov 2011
        • 1253
        Yeah I know that's why I can't wait to get down there and check. That ratio will be perfect for my eta.
        • kid325e
          • Sep 2007
          • 6422
          Finesse and weight transfer drifting is so much more fun to watch than a guy with a V8 just burning out the whole time. Anybody can power over.
          clutchCTRL!
          Move with a purpose.
          - 1991 325iX 4dr/5spd
          - 2000 323i AT
          2016 Mazda CX3 Sport AWD
          • FunfGan
            • Jan 2011
            • 4958
            Originally posted by camip
            I think I'm gonna scrap the 302 idea and swap an 855 head on my eta and see how it goes from there.
            Go here be happy!
            Ratchet Garage e30 V8 build.
            • camip
              • Nov 2011
              • 1253
              This is very true.
              • eurotrash
                • May 2007
                • 768
                Let me help shed some light on the subject. Ive got a 302 e30 not a 5.0 but a 302. Heres what your going to need to get it done. You need to order the swap stuff from e30v8.com unless your comfortable with designing and welding your own mounts/oil pan. Then you will need a 4 barrel holley(speed demon and quick fuel tech are also holley based but more expensive) double pumper in the 600-650 range and it order your self the wedge floats to help with fuel slosh. Ull also need an aluminum 4 barrel intake. U need to get either a low pressure external fuel pump or like a walbro intank pump dep on if its a early or late model car. Then u need a fuel pressure regulator so u can keep fuel pressure at 6-8psi. u'll also need to get ahold of modern drivelines and buy a conversion fly wheel as its the easiest option to bolt on the diaphram style clutch that ull need for the t5 tranny unless u decide to run an older 4 speed. U'll also need to get a slave cylinder and a hydro clutch line.
                Now for the facts u really want to know. The 302 stock to stock is about 80lbs heavier. This is nul and viod when u consider your removing 2 cylinders from hanging off the front of the axel it also sits much lower and u can possition it farther back towards the firewall. Next you throw in the options of aluminum/billet accesories/heads/waterpump/intake and get rid of the cast manifolds for either a longtube or a mustang gt/lightning shorty header and your much lighter then the m20. Power wise it really comes down to the fact that your not going to be doing worse then 200/250 wheel hp/torque on any configuration of 302 with the required intake/carb. The reason some 302s were underpowered was emisions and tiny carbs and bad flowing intakes. You do a cam/aluminum heads/intake/carb/ and your looking at around 300 wheel and upto 350-400 with proper combos and compression. You can get the same numbers from a turbo m20 but itll be alot effort and tuning.
                My build as a referance.
                • camip
                  • Nov 2011
                  • 1253
                  ^enjoyed your build. But sadly it turned me away from the 302 even more. Not sure I'm ready to attempt that as of right now.
                  So the plans thus far are
                  1.855 head swap
                  2.Switch over I electronics after head swap and recoupe money
                  3.Wheels
                  4.hydro e brake
                  anything else?
                  • eurotrash
                    • May 2007
                    • 768
                    Dont waste your money on a hydro ebrake uve got suspension and track time to pay for b4 u worry about a hydro ebrake
                    • camip
                      • Nov 2011
                      • 1253
                      I'm currently running hr race springs and blistien sports. Would I be better off selling the hr's and buying the GE coil over springs?
                      • FunfGan
                        • Jan 2011
                        • 4958
                        Coils would definitely help you a lot. I also agree that you shouldn't waste your money on a hydro brake, at least right now.
                        Go here be happy!
                        • eurotrash
                          • May 2007
                          • 768
                          Bilstein races are actually decent enough spring rates i think but the adjustment of coils cant be beat.
                          • camip
                            • Nov 2011
                            • 1253
                            so looks like i need to find a lsd then wait on everything else. What is a good spring weight for drifting? keep in mind this is my daily driver too but I don't mind a rough ride.
                            • FunfGan
                              • Jan 2011
                              • 4958
                              The ideal? You'd want about 950/1100. I run 450 and 700, though I definitely want to up it a few hundred.
                              Go here be happy!
                              • camip
                                • Nov 2011
                                • 1253
                                Thanks for all the info guys. Another question what about tires how quick do the go do you buy new or just used sets?
