Which Diff Ratio to Use??
  • porschelou
    • 135
    We are headed to Watkins Glen in April for some racing. The car is a 86 325e with a 3.5 b34/m30 motor(roughly 200hp and good TQ #'s). We have been using a 3.73 LSD gear ratio for the last many years. At VIR we noticed on the straights we don't rev out and can only hit about 121mph - need a lower gear to get up to speed faster. So, we ran out and got a used 4.10 LSD but now we think that might be too low. If we do the math:
    Our Transmission gear ratio’s
    1-3.83
    2-2.20
    3-1.40
    4-1.00
    5- .81
    Current 3.73 ratio
    RPM MPH
    5000 113
    5500 124
    6000 136
    3.91 ratio
    RPM MPH
    5000 108
    5500 119
    6000 130
    4.10 ratio
    RPM MPH
    5000 103
    5500 113
    6000 124
    We have never run WGI before but watching video's it's a very fast track. It seem like a 4.10 might be too much. 3.91 seems like a better choice. Looking for some expert opinions out there. We have started the search for a good used 3.91 in case that's the direction we need to go.
    Thanks
  • seatown88
    • 331
    what size wheels/tires are you running? It seems like you may want the 3.91 diff, or switch tire size.
    • ukrbmw
      • Jun 2008
      • 156
      WG is similar in top speed to VIR.
      Do you have data - TM or anything similar? Sometimes speedo can be off in terms of what speed you are actually running. 3.91 does seem to be a middle ground, however 4.10 is probably easier and cheaper to get (unless you already have a 3.91 sitting at home). Other option as the person above mentioned is to go to a slightly taller tire and 4.10 so it would be almost like a 3.91.
      • porschelou
        • 135
        We use 15' wheels with 205/50/15's. We don't have any real data. We have a 4.10 but have started shopping for 3.91. We will have a test/tune day prior to the races. This would give us an opportunity to swap diff's if needed. I wish we could change aspect ratio on the tires but we are limited to which tire we can run.
        Thanks for the info..
        • TobyB
          • 5287
          I'd do the 3.91, just from your calculations...
          t
          • Emre
            • Sep 2007
            • 1228
            WGI is one of my "home tracks" (along with Mosport and Tremblant). If you'd like any tips, feel free to ask here or by PM.
            With a stock M20B25 engine and 225/45-R15 tires, the 4.10:1 LSD is perfect. The shift points line up exactly where you want them to be in order to put the power down coming out of the critical corners.
            With an M30B35 and the same-sized tires, I would expect the 3.73:1 LSD to be just about right. Personally, I wouldn't bother with the swap.
            If you try to gear the car such that you'll max out in 5th gear at the top of the back straight, you'll be in-between gears in some of the critical corners. I really don't think it's worth it.
            That's a little puzzling. You can easily fit 225/45-R15 under the stock wheelarches. That extra width really makes a difference in the high-speed corners.
            The difference between the 4.10:1 and 3.91:1 is so small that you can easily make up the difference by playing with tire size. Assuming you're starting with the 225/45-R15 (which you should be!), all you need to do if you want slightly taller effective gearing is to switch to 225/50-R15 rubber.
            No need to hunt for a 3.91:1 rear end. They're hard to find and good ones are expensive.
            1987 Mercedes 190E 2.3-16: Vintage Racer
            2010 BMW (E90) 335xi sedan: Grocery Getter
            • djjerme
              • 5082
              Go with the shorter tire and 4:10, the shorter sidewall should give you a little more response/feel in the corners/braking zones.
              2016 Ford Flex
              • yeaseth
                • Jul 2011
                • 302
                my orignal ratio was 3.73, then I ran a 3.91 for a while and didnt like how short it was so I switched back to the 3.73
                benvideoproductions.com
                http://www.youtube.com/watch?v=617yNrOrRfo&
                • Jparkr
                  HR Admin
                  • Jan 2006
                  • 3494
                  Our pro3 15s with 50mm sidewalls keep the 4:10 ratio, when we run on 45mm sidewalls it turns into a 4:27 if I remember the rule meeting convo right.
                  That being said OP I would run a 3.74 with a smaller sidewall to make a 3:9x ratio.
                  We also have an M30b35 chumpcar and run a 4:10. More than happy with it Straight away speed is ok but power exiting corners will make you much more competitive.
                  1987 PRO-3 car /1990 325is (2.7i Concours)
                  • Fusion
                    • Nov 2009
                    • 3659
                    Which 4.10 will take the M50 or M30 power? I hear the small case LSDs will pop.
                    • Emre
                      • Sep 2007
                      • 1228
                      Small case (from the '91 318is) won't survive an M20, let alone an M30 or M50. Ask me how I know!
                      If you want to swap, you'll need a medium-case 4.10:1 LSD from an E30 M3.
                      • Emre
                        • Sep 2007
                        • 1228
                        Agreed. The OP should keep his 3.73:1 LSD and run 225/45-R15 tires on 15x8" wheels.
                        • ForcedFirebird
                          • Feb 2007
                          • 8300
                          Any 318is that was originally purchased with the optional LSD came in medium case, same with the automatics. My auto was ordered with LSD (auto came with 4.10), swapped in a manual and am using it on the track. Homestead is a shorter track than the above mentioned ones, so difficult to give advice.
                          john@m20guru.com
                          Links:
                          • M-technik-3
                            • 18946
                            Or a convertible automatic.
                            • Wh33lhop
                              • 11705
                              Originally posted by ForcedFirebird
                              Any 318is that was originally purchased with the optional LSD came in medium case.
                              I think you are wrong on this. Medium case 4.10s can be found on (some) auto 325is and M3s. 318is all came with small case 4.10s, some open, some fun edition.
                              paint sucks
