Top speed limiter
  • TobyB
    • 5298
    Top speed limiter
    What I learned last weekend: the latest ECUs have a top speed limiter at 125 mph.
    What you do, in a hurry- unplug the diff sensor.
    I'm running a -524 ecu, because it was there, no chip.
    When we switched from 225-50-15 to 225-45-15 RA1's
    (there's a BIG circumference difference,on the order of 3")
    we started getting into it at the end of the
    front straight, at about 6000rpm.
    At first, I thought it was a fuelling issue, but it was too consistent,
    always right at 125, and it wouldn't do it in 4th, nor pulling hard up
    out of t6, which usually shows up a fuel issue, too. After some trolling
    around the paddock begging for help, and a bit of research(thanks, James) I bumped into
    one other person who'd seen it (thanks, Chuck!) so we unplugged the diff.
    And that fixed it. He said they had a problem with it even with a chip...
    Things you know, things you think you know, and things you learn...
    t
    #100
    dfl, last weekend. But hey, I finished...
    obviously, I suck at search...
    Yep, a 524 DME has a speed limiter. But you can disconnect the wire to the engine harness that supplies the speed signal to disable it.
