Tire question for track (HPDE)
  • el bimmer
    • 900
    Originally posted by SmokeE30
    I would not run 15s up front with 16 in the rear. Just spend the 50 bucks for a set of spacers to clear the strut or borrow a spacer from somebody untill you kill the tires then order a 45 series sidewall
    Cool thanks for the information.
    • Wh33lhop
      • 11705
      TRM C1s come in 15x8 +~20 5x120. They clear E30M brakes.
      paint sucks
      • serdar255
        • Feb 2013
        • 395
        Will they clear the uuc bbk?
        image (10) by serdar.gurhan, on Flickr
        PM me for custom shift knobs and stickers!
        Originally posted by marshallnoise
        You ain't done working on a car unless you are bleeding.
        • FLG
          • Sep 2011
          • 3165
          More then welcome to try mine on to make sure. Though I'm 4x100
          Sent from my Galaxy Nexus using Tapatalk 2
          -Build http://www.r3vlimited.com/board/showthread.php?t=295277
          • Wh33lhop
            • 11705
            wut
            we are talking 5 lug here
            paint sucks
            • FLG
              • Sep 2011
              • 3165
              wut
              I wasn't sure if he was 5 lug I figure I'm local if he wanted to see if they would clear, I assume he was running a uuc bbk and wanted the tr c1's
              • el bimmer
                • 900
                I am running 5 lug, but not BBK
                • FLG
                  • Sep 2011
                  • 3165
                  Gotcha.
                  • Cephas
                    • Apr 2012
                    • 878
                    I'm running the Toyo Proxes R888's 225/45 on 16's with a 10mm spacer. The wheels are BBS RX's and I have the offset M3 solid bushings from Condor. No rubbing up front or rear.
                    Lots of back and forth on this tire on the Spec forums, but I just had my first HPDE on them and thought they were fantastic.
                    • el bimmer
                      • 900
                      Do you have spacers in the rear as well? I really do not want to use spacers for track. It's just my personal preference, but very thankful for the information. This information really made me understand what I will really need in the front. Thanks again.
                      • Eric
                        • 5138
                        buy quality spacers and you won't have a problem. if you look at most club/nasa race cars, spaces are often used.
                        of the 7 sets I've owned, i liked VAC spaces the best.
                        • FLG
                          • Sep 2011
                          • 3165
                          I'm also running spacers, 20mm motorpsort hardware spacers and extended studs. Both quality products, no vibration or issues.
                          • el bimmer
                            • 900
                            Cool great to know!!! So with styles 5 from an e38 with 225 45 16, 10 mm should do it?
                            Great info!
                            • Bimmerman325i
                              • 6854
                              I'm tracking on 10mm spacers with hub extenders from Turner, with vorshlag studs.
                              No problems.
                              2017 Chevrolet SS, 6MT
                              95 M3/2/5 (S54 and Mk60 DSC, CARB legal, Build Thread)
                              98 M3/4/5 (stock)
                              • z31maniac
                                • 17566
                                Are you planning on doing lots of track time, or just a few times a year?
                                If you are going to do it more than occasionally, I'd consider getting something less aggressive for the street, and having a dedicated set of track wheels/tires.
                                15x8s that Wh33lhop mentioned +225/45 NT-01/R888/Rivals would make a killer HPDE setup for an E30.
                                www.gutenparts.com
