Need some Harness advice
  • Jb325is
    • 2137
    GForce are good for budget harnesses, if you want to spend a little more for a better product go with Safecraft. I don't find G-forces to be comfortable at all. I deal with all the different brands at work and Schroth are great quality as well but they are a PITA to install and adjust. The adjuster/slider mechanisms on the Safecrafts are awesome
    - '88 m54 coupe
    <3
    • JRKOUPE
      • Dec 2004
      • 3159
      Ill add one more thing to confuse you.....I instruct at many DE's I go to, so i get to feel alot of brands. IMO.....its not worth going for big buck belts unless funds are not an issue, and you are a brand type of consumer. I recall Schroth giving me a bad neck rub in one ride....
      Ive had Gf yrs...no issues...ever. The GF pro series are even softer than they used to be...you want a nice pliable webbing....
      go to an event...check out all the cars.......done.
      you really cant go very wrong w/ any choice here...
      • FLG
        • Sep 2011
        • 3165
        G-force 6 point in my track rat (same cage as you) and they're great. I also kept the stock belt for driving around.
        You can also use one eye bolt in the stock lower holder that's in the car, same threads... Saves you from drilling another hole.
        Sent from my SCH-I545 using Tapatalk 2
        -Build http://www.r3vlimited.com/board/showthread.php?t=295277
        • kingston
          • Jun 2010
          • 2669
          The Safecraft stuff looks like the ticket for me. Great thread - thanks guys!!
          Originally posted by LJ851
          kingston is the play by play announcer for this thread.
          ‘Tis by the grace of God that my cars run!
          Originally posted by unloadedak
          #teamross
          Siobhan's Build Thread - UPDATED!
          • GThomas
            • Dec 2010
            • 869
            I ended up going with the 6 point Racequip belts. Really like them.
            1991 318is S52
            1987 325i Vert
            1991 325i
            2011 e70 X5
            Need Anything E30? -> http://www.gutenparts.com/
            • TobyB
              • 5203
              Did they come with a naked girl?
              I always hoped they would, but not enough to buy the harnesses.
              t
              • Chriskbmx
                • Apr 2012
                • 972
                can someone post a link for how to install the belts properly?
                • FLG
                  • Sep 2011
                  • 3165
                  Chris if I get some time I can take some pics for you. It's not terribly hard.
                  • JRKOUPE
                    • Dec 2004
                    • 3159
                    tonsa info online......tons dude.
                    get all your angles right.......
                    gforce site
                    schroth site etc...
                    apex racing
                    saferacer
                    • FLG
                      • Sep 2011
                      • 3165
                      gforce site
                      schroth site etc...
                      apex racing
                      saferacer
                      That too. Schroth has a lot of info on YouTube.
                      • TobyB
                        • 5203
                        no naked girl, huh....
                        t
                        • Chriskbmx
                          • Apr 2012
                          • 972
                          thanks guys, I can understand anything, just finding the right info can be tough.
                          • M-technik-3
                            • 18946
                            We run G-force as well in our lemons rat. No complaints.
                            • djjerme
                              • 5082
                              When in doubt, check out one of the rule books for a racing organization. They usually will break it down for you. SCCA and NASA have good sections on belt routing and what not. The areas to pay attention are:
                              -The angle of the upper belt from your shoulder/seat to the harness bar
                              -the angle of the anti-sub belt from the mount through the seat.
                              -looping the belts through the adjuster, the anchor or around the bar and back through the adjuster.
                              Once you get the hang of it, try uninstalling and reinstalling them a couple times. It doesn't take long to get quick at threading them, and it will help you set them up correctly for whatever size driver is in your car.
                              Also, make sure to set them snug in your lightest street clothes, then they will be very snug in your race suit (which is what you want...)
                              2016 Ford Flex
                              • GThomas
                                • Dec 2010
                                • 869
                                Anyone have any tips on mounting the inside lap belt? Could I mount it to the Vac mount?
                                1991 318is S52
                                1987 325i Vert
                                1991 325i
                                2011 e70 X5
