Lotus Cortina race video thread! All videos in first post!
  • ELVA164
    • 4861
    Updated 12/11!
    To cut down on confusion, I'll list all my videos here in chronological order:
    Summit Point 11/2012, Saturday Race
    Summit Point 11/2012, My leg of the Relay Race
    Summit Point 5/2013, IMSA Reunion Race
    Lime Rock 6/2013, My First Session Ever
    NJMP Lightning 9/2013-First clutchless shifting, missed shift, lost coil wire and retirement
    Summit Point 11/2013, Close Race with Elva MkIV
    Summit Point 5/2014, My leg of the Enduro
    Summit Point 5/2014, IMSA Reunion (one of my favorites)
    PIRC 7/2014, Very busy qualifying with lots going on
    PIRC 7/2014, Saturday Race
    NJMP Lightning 9/2014, Shifter breaks during session
    NJMP Lightning 9/2014, Qualifying with broken shifter
    PIRC 7/2014, Short funny clip of my throttle cable detaching on the qualifying grid
    Summit Point 11/14, the Cortina's final session before getting crushed.
  • JRKOUPE
    • Dec 2004
    • 3159
    a HANs..you have a Hans......!!!!!.........good to see.
    I love that track...sorry I couldnt get out there.....
    very nice drive...impressive that you can hang w/ that sr...oops..you passed him...lol
    was the HNR a hindrance at all you?
    • QUKBMER
      • 8178
      Nice video bro. I love lotus cortina's.
      • ELVA164
        • 4861
        Haha, Dad and I share it. It wasn't much of a hindrance to me because I don't need to turn my head much to see my mirrors. It just took a bit of getting used to when I strap in.
        Thanks, there are more on the way!
        • Wh33lhop
          • 11705
          Ah clutchless shifts.. I was wondering how you managed to shift so fast. Are you in the same class as the mid-engined car ahead of you?
          paint sucks
          • ELVA164
            • 4861
            Yeah, I decided to try it for the first time because the clutch was only barely working so I wanted to be prepared. I only did it from 3 to 4 most of the time though. I'll probably go back to using the clutch once it's fixed. Yes, he was in the same class.
            • ELVA164
              • 4861
              Here's footage of my second race that day. The Austin Healey was a no-show, so it was a duel between me and the Elva:
              I was really happy with the outcome because the two cars have the same powerplant, but his weighs about 750lbs less, isn't a brick, has 4-wheel disc brakes and all-independent suspension, and a 5-speed transaxle.
              • robgoesvroom
                • 821
                that sounds awesome. Do you have any side by side pictures with an E30? I just want to get an idea of the size difference
                • ELVA164
                  • 4861
                  I don't but I'll have to do that! I can tell you it's almost the exact same dimensions as a 2002 though.
                  Edit: Here you go! Set them next to each other today.
                  Gratuitous engine shot!
                  • ELVA164
                    • 4861
                    Here's my third race of the weekend. I had a rematch with the Elva and had a good back-and-forth with him. I had a lot of fun trying to get back past him when he outbraked me into turn 1 about halfway through the race. I also started to run out of brakes, tires, and clutch by the end of the race so there was a lot going on in there! So much fun.
                    • JRKOUPE
                      • Dec 2004
                      • 3159
                      MC
                      Im looking at strut tower area in Cortina....
                      did u redrill holes to gain neg camber?..
                      you dont run camber plates...not allowed?....do u run coilovers?...I assume not?..
                      • ELVA164
                        • 4861
                        Those holes were drilled by a PO and we decided to use them. Looks like somewhere around 1degree each side. No camber plates. Not sure if they're allowed or not, but I have proposed the idea to Dad for the future. The car does have coilovers in the front, leaf springs in the rear.
                        • ELVA164
                          • 4861
                          Okay, adding videos one race weekend at a time! This post is from exactly one year before the above videos. This is also my first full race weekend in a race car. In these videos, the car still has a syncro gearbox and I REALLY like trying to shift from third to reverse instead of third to second. :/ I fixed that in the future, it's never happened since.
                          The race is split into three parts for ease of watching. It's tough to see, but I'm racing an Elva MkIV sports racer which is right behind me.
                          • ELVA164
                            • 4861
                            These videos are from last Thanksgiving at Summit Point in West Virginia. It was a bit more of a laid-back event (untimed, etc.) but I didn't take that as reason not to see what the car could do. Turns out that the handling issues you see in this video are a result of no front camber, incorrect front caster, rear trailing arms that were keeping the rear of the car from moving properly, and an overly-soft rear damping. Other than that, it was great. :razz:
                            • ELVA164
                              • 4861
                              These videos were back at Summit, but this past May at the Jefferson 500. I was given a couple drives by our generous drivers and took the opportunity! Unfortunately, the tires had been severely beaten up already, as had the brakes. It was still a ball!
