Any new autocross tires on the horizon?
  • GThomas
    • Dec 2010
    • 869
    Hey guys,
    About to get a set of Rivals (225/45/15) on the KoseiK4R (15x8 only that i know of that fits over the UUC BBK). I had the new Direzza ZII's (205/50) on 16x7's for this past year and really enjoyed them but felt with the large sidewall and small contact patch of the 50's that 15x8's would be better.
    Does anyone know of any new tires for 2014 or wheel selection that I should wait on before i pull the trigger on this setup?
    1991 318is S52
    1987 325i Vert
    1991 325i
    2011 e70 X5
    Need Anything E30? -> http://www.gutenparts.com/
  • E30 Racer
    • Nov 2004
    • 427
    Looking for a street tire or the real deal?
    Garrick
    1989 325is
    DSP #72
    • GThomas
      • Dec 2010
      • 869
      Went with Rivals on 15x8's. Street tire class is the most competitive in my chapter and I like driving to the events with them on already.
      1991 318is S52
      1987 325i Vert
      1991 325i
      2011 e70 X5
      • tinkerputzer
        • Jun 2008
        • 508
        Let us know how you like them on an 8. My next set of tires will probably be rivals too. Just trying to decide if i want to go with 205's or 225's. I'm on 8's too.
        • R3Z3N
          • Jan 2011
          • 3056
          If you are on 8s I would use 225. 235 would be ideal.
          • Wh33lhop
            • 11705
            225s on an 8 may not actually gain you any time over 205s, depending on how wide rivals run.
            paint sucks
            • Cabriolet
              • 9620
              225/45/15 RS3 fit very well on 7 inch rims if you are running 8's at taking the points 235s should be the size to run if you can get them in your size
              Much wow
              I hate 4 doors
              • tinkerputzer
                • Jun 2008
                • 508
                Pretty much what the recent tire comparison in grm said. Wheel width should be equal to or greater then tread width. Iirc 225 rivals are 8.5" tread width and 205's are 7.8" That being said i still want to hear op's impressions of the 225's on 8's.
                • Wh33lhop
                  • 11705
                  It varies between tires. Some run wider than others.
                  225 RS3s are much better on 8" rims than 7". They were about square on my 8s. The 205 R888s that I ran on the 8s afterwards were also square, as they run wider.
                  paint sucks
                  • Wh33lhop
                    • 11705
                    Yep, 225 rivals weren't any faster on 8s than 205s. With the 225s on 9" wheels they picked up a lot of time though.
                    This is a problem everywhere. People try and stuff as much rubber on their wheels as they can, and eventually find out that it isn't any faster than properly sized stuff.
                    paint sucks
                    • Cabriolet
                      • 9620
                      true they(r-s3) are designed for a 7.5" rim so they will work on 8's perfectly. in the bmwcca it's all about saving points so the extra 4pts for the rims sucks when u are running the same rubber. but scca is very different and i defer to your opinion on running that wide.
                      Much wow
                      I hate 4 doors
                      • Wh33lhop
                        • 11705
                        Extra points always suck, but that same rubber's properties will vary greatly depending on your wheel width. A 225 on a 9" will be much faster than a 225 on a 7".
                        paint sucks
                        • R3Z3N
                          • Jan 2011
                          • 3056
                          ^Agreed. With a lower HP car, one must also think about tire/wheel combo mass. For those that are not following wheelhops and cabs conversation, essentially a narrow tire on a wider rim is generally ok (to a point) but a wide tire on narrow wheels is slower. Another thing to think about is the horsepower of your car, vs tire mass, hence why going to something absurd like 10s all around will probably slow our cars down.
                          My old Z1s (235) on a 8.5x17in rim perform just about perfect, and are stretched ever so slightly (quite close to square profile honestly), and z1s are said to run wide.
                          • tinkerputzer
                            • Jun 2008
                            • 508
                            Also i think the proper sized tire gives much better feedback to the driver.
                            • klodkrawler05
                              • Apr 2012
                              • 253
                              This is a good point as well, at some point the weight/resistance/extra track width of a wider tire/wheel will slow you down, however I'm surprised you feel that a 10" wide wheel is that point, seems that even the 100hp miata guys find 9-10" wide wheels with 225 street tires or 275 wide slicks are still faster than anything narrower.
                              One other thing to consider would be gearing advantage, the 235 on a 17 that you mention (I assumed 235/40/17) is 24.4" tall while both the Hoosier 275 and the rival 225 are only 23" tall, that helps lower your center of gravity and also provides a bit more grunt out of corners vs the taller 235
                              of course if you're already hitting the rev limiter in 2nd regularly then the shorter tire probably isn't going to help as much but if you typically aren't hitting the limiter in 2nd the gearing may help!
                              -Brad
                              My E30: http://www.r3vlimited.com/board/show...50#post3916850
