Taper pad wear with Girling calipers
  • TobyB
    • 5287
    so the last set of front DTC 60's had terrrible taper wear- way worse than the
    previous 2 sets of Hawk Blues did.
    Other than changing the guide pins, is there anything else I could do to
    the calipers and carriers to get taper wear down? I hate having to rotate
    pads, but I hate even worse to have to throw half a set of pads away...
    In measuring the spare carriers, I discovered that one pin is a
    significantly tighter fit than the other- apparently by design. The pins
    are a bit (.05mm) shy of 8.5mm, and one guide hole is 8.50 mm.
    The other is 8.7mm. This is consistent across 4 carriers. Near as
    I could guess, it's to reduce binding. I'm almost tempted to sleeve a set
    to 8.50mm on both, and see if it works.
    Because race car.... and yes, it WOULD be cheating, of course.
    t
  • kronus
    • Apr 2008
    • 13032
    You can switch out the rubber guide bushings for brass ones, according to people. I have a set like that, but the one time we ran them on track we had a lot of front brake locking issues.. I fear they may cause the thing to bind.
    cars beep boop
    • TobyB
      • 5287
      The Girlings are very different than the ATE's that have rubber bushings-
      the Girling runs an 8.5mm pin inside the casting of the carrier, and just
      uses a wad of grease to prevent wear.
      I wonder if opening up the clearance on ONE ATE brass bushing
      (to make it like the Girlings) would reduce binding- I've heard stories
      from those running the brass bushings that they've had binding
      problems too...
      t
      • kronus
        • Apr 2008
        • 13032
        Yeah, I am talking about girlings. I have a set of girlings with brass bushings. I'll snap a pic next week.
        cars beep boop
        • TobyB
          • 5287
          Oh, wacko- yes, please, a bushing pic might explain what I'm missing.
          Thanks!
          t
          • Ocell
            • Apr 2013
            • 291
            I've never seen a brass bushing setup for Girlings. I'm curious to see what the setup is.
            91 318is Members' Rides Thread
            • ForcedFirebird
              • Feb 2007
              • 8300
              Same here.
              john@m20guru.com
              Links:
              • FLG
                • Sep 2011
                • 3165
                What they said...^
                -Build http://www.r3vlimited.com/board/showthread.php?t=295277
                • Roland H
                  • 4480
                  weird. Used to run brass bushings front and rear and never had locking issues. Made sure to lube em up every time I had a wheel off the car and sometimes just for fun though.
                  of course I ran them on the vastly superiour E36 M3 and not an E30.
                  • bmnut2002
                    • Nov 2009
                    • 198
                    Toby,
                    I have rebuilt ATE calipers in stock. I'd suggest changing over.
                    Kevin Doyle
                    KD Motorsports
                    KD.Motorsports@yahoo.com
                    9175 Willows Rd NE
                    Redmond, WA 98052
                    (425)556-9076
                    • TobyB
                      • 5287
                      Why, Kevin?
                      What advantage do the ATEs have over the Girling design?
                      t
                      • bmnut2002
                        • Nov 2009
                        • 198
                        Toby,
                        Less caliper flex and more even pad wear.
                        Kevin Doyle
                        KD Motorsports
                        9175 Willows Rd NE
                        Redmond, WA 98052
                        (425)556-9076
                        • TobyB
                          • 5287
                          Well, I'll admit that the Girlings are pretty bad for taper wear...
                          ...smaller pins might account for a lot of that, huh?
                          t
                          • lcoleman
                            • Jan 2009
                            • 331
                            I upgraded to Ate calipers with the brass guides, and improvements have been modest at best. I'd say it's worth a shot, though. Just go to RX7 or Willwood stuff unless you're running SpecE30.
                            • TobyB
                              • 5287
                              Pro3.
                              t
